cornish mafia
#1
by cornish mafia » Tue May 22, 2012 9:15 pm
OK you gods here goes ..............and yes I have had a look in search before asking I promise ( and yes I know you'll probably find one showing me I never looked hard enough after I’ve ask as well !! ) BUT
Has anyone ever joined the brake light to be used as the indicator as well and then freeing it up for a high level can by getting rid of the rear indicators......
Just an idea which I obviously didn't look into when buying the bloody high level RSV can
............Looks like it'll work but just doesn't quite fit , back to old can till I can sort something out.........
Ideas gentleman.......And NO TWAT isn't an idea !!!
#2
by D-Rider » Tue May 22, 2012 9:19 pm
Not legal so no point in attracting unwanted attention.
That said, Nooj has recently released an integrated tail light/flasher set that is closer to legality than flashing one of the tail lights (spacing of them is closer than supposed to be though)
Have a search and you'll find it
#3
by Aladinsaneuk » Tue May 22, 2012 9:33 pm
Or have a very close look at assorted images of my bike over the years
Here's a hint - acquire a spare grab rail and cut it down. The side mounts for it will be available then. The alloy takes a tap and then a set of threaded indicators can be fitted easily
Also adhesive blister types are easy to fit to the rear cowl - look at caravan part suppliers
The solution that I commissioned Nooj to make does look awesome btw
#4
by HowardQ » Tue May 22, 2012 11:56 pm
It can be done by using any slightly smaller indies and a bit of fiddling.
See examples of Tweaker's ex bike that my mate Dave recently sold to Musclebiker.
This set up is with Rene's
No real problem.
Take a ride on the Dark Side
2001 Aprilia Falco in
Black
#5
by furygan man » Wed May 23, 2012 12:47 pm
...you could use hand signals!
#6
by D-Rider » Wed May 23, 2012 12:58 pm
I don't think anyone has yet had a go at fitting a set of these
cornish mafia
#7
by cornish mafia » Wed May 23, 2012 1:07 pm
That's about as close as my one is sitting to the tail unit on mine, does it damage the paint work? ........Am liking the idea of maybe using the grab rail as a flash point so to speak.....Going to have to change my plate and go back to a more square one to let it fit but thanks for the ideas....
#8
by D-Rider » Wed May 23, 2012 1:13 pm
I'd thought about doing something in the grab rail .... but decided that I'd better have something that's not going to be obscured by the pillion
- Wear the Fox Hat
#9
by randomsquid » Wed May 23, 2012 1:32 pm
D-Rider wrote:I don't think anyone has yet had a go at fitting a set of these
Thought about it. But would need to be longer and able to support a spinning blade.
cornish mafia
#10
by cornish mafia » Wed May 23, 2012 1:44 pm
That's easy pillion pegs have gone anyway ..........Seen these on ebay for a possible maybe : - 180870779467 , all just ideas
#11
by Aladinsaneuk » Wed May 23, 2012 2:23 pm
cornish
when i started to move things around, i started off with some cardboard to cut too shape etc - then i could make brackets and things.
Think laterally - you would be amazed what will bolt onto a number plate..... and where :)
#12
by MartDude » Wed May 23, 2012 2:25 pm
Go even more retro - hand signals?
#13
by furygan man » Wed May 23, 2012 2:27 pm
Aladinsaneuk wrote:cornish
+1 B&Q is your friend!
cornish mafia
#14
by cornish mafia » Wed May 23, 2012 4:17 pm
Just been banging head around in the garage and may of come up with something ...........all ideas taken onboard as well !! For once it would be nice to get something that just fucking fits straight away.................forgive my french !!..
#15
by D-Rider » Wed May 23, 2012 4:20 pm
cornish mafia wrote:Just been banging head around in the garage and may of come up with something ...........all ideas taken onboard as well !! For once it would be nice to get something that just fucking fits straight away.................forgive my french !!..
Haha - go back to standard set-up .... all of that fits together fine
