Bike abandoned in Birmingham as for the second time it refuses to start after a night out in the rain. This never happens when I'm at home, only when it's really inconvenient and I'm 40 miles from my battery charger!
Well Mr.Falco... if you get nicked then you've only got yourself to blame. If you're still there on Friday then you had better have sorted yourself out!
*harumph*
Bah - damp again
- KitchenSync
Starting with the simple things ..... what's your starting technique?
The method specified by Aprilia is usually pretty effective.
Of course you could have got some other problem such as water in the electrics or one of the sensors or something - but might as well start with the simple stuff
- Fast Idle fully open
Don't touch the throttle
Hit the starter and wait for it to fire
- Hold the throttle fully open and crank until it fires and clears itself.
- KitchenSync
Ta
Thank for that.
It usually catches within one turn. Mind you... on the way home on the train I did wonder if some scallywag had flicked the kill switch (I didn't check it).
I'll be back in a couple of days with some jump leads - I didn't want to run the battery out and with it raining all day there was no prospect of the thing drying out. The last time this happened - 4 weeks ago, there was a real heavy fog but it was trying to fire until the battery died.
Probably best out of the weather - although it does live outside at my place, albeit under a cover.
- flatlander
Well I going to tempt fate as I set off this morning in the shotty weather and so far the bike is coping a damn site better than me. Though sometimes the day after it complains. I would say if the battery is suspect best changing it as apparently it can contribute to faking a sprag
- flatlander
So fR so good as I am at Buxton buying kitchen gloves still got to get over cat and fiddle
