Pressure in the tank
musclebiker
#1 Post by musclebiker » Wed Apr 11, 2012 2:13 pm
Came back from a ride on the bike, went inside for 10 mins or so and then back out to put it away.
I noticed fuel leaking from the top of the tank. Opened the cap and fuel spurted everywhere including in my face (don't laugh)
So I assume my tank is not venting properly. Does anyone know whether the vent is in the cap or underneath the tank on a Falco?
Tonyunn
#2 Post by Tonyunn » Wed Apr 11, 2012 2:21 pm
From the manual:
"Open the filler cap and make sure the vent on the tank
is not clogged. where necassary, unclog it using a compressed air jet."
After looking at that I assume the vent you want is up top.
Speed Blue SL 1000 Falco
Re: Pressure in the tank
#3 Post by D-Rider » Wed Apr 11, 2012 3:00 pm
Good thing you aren't a smoker !
There are a number of pipes in the top of the tank
Bst thing to do is have a browse of the workshop manual: http://www.martinpoll.dk/div_april.htm
Download the OCR version from Martin's site - that one is searchable
#4 Post by Aladinsaneuk » Wed Apr 11, 2012 6:52 pm
I would start with the 3 pipes tucked down by the front sprocket cover
Undo the petrol cap and try to blow up each piPe
If one is blocked - and I suspect it will be, then takeout will be the drains at the bottom of the tank - normally you would get to them by lifting the tank but if you can get to them, disconnect the pipes and then use a pipe cleaner to ream the tubes clear
Be aware that lifting the tank can be a pita to return - the tanks grow !
musclebiker
#5 Post by musclebiker » Wed Apr 11, 2012 9:54 pm
much very thankyou
