first question is, it's a gen 1 swing arm i'm hoping to get but at the moment i have a white spring mille shock fitted with falco linkages, will i need the mille linkages to fit the shock when i fit the new arm?
2) i have read the mille arm adds ride hieght, is this true?
i allready have the shock set at it's lowest and i still struggle a little to get my feet flat on the ground
Thanks guy's
