What's wrong with this pic - its the rear cylinder head at TDC
Answer - the exhaust cam is pointing the wrong way!!! the right hand camshaft should be pointng to the right not left!
I think this is what they call a 'spun camshaft'
Basically I've been trying to get my old falco running again after standing for nearly a year.
It had been very reluctant to fire but finally did and roared off to the revlimiter then stalled - since then trying to get it to run has been nearly impossible with massive blowback through the rear throttle body.
I knew something was wrong - but didn't expect this!
New/replacement camshaft will be required me thinks
Anyone got one?? and does anyone know are the front and rear cams interchangeable?
Taq
