As above, I need a gen 1 bottom clamp off a Mille or Tuono that had Ohlins. The hole size needs to be 56mm.
Gen 2 is no good as the offset is diffrent.
Anyone able to help?
Wanted, bottom tripple clamp Gen 1
Re: Wanted, bottom tripple clamp Gen 1
I'll double check but don't think I've got one of them.rossguzzi wrote:As above, I need a gen 1 bottom clamp off a Mille or Tuono that had Ohlins. The hole size needs to be 56mm.
