I know this is a "how long is a piece of string" question but after riding I have an oil leak which dissapears once the oil engine is cold.
Are there any nailed on places where I should look to cure it.
I checked the filler cap because it looked cross threaded but I seem to have sorted it.
No obvious signs from oil drainer bolt (looks really small ) and the engine itself looks very clean and dry.
Oil leak
I've heard the cam cover seal on the front pot where the camshaft sensor goes through can sometimes leak - usually after a service when it has been removed to check the valve clearances.
I seem to remember some having leaking oil pressure switches.
Apart from that I guess any seals and hoses - but with it happening when you are running, I'd suspect somewhere near the top of the engine or that gets more pressured while running - like those first 2 suggestions.
Thanks, at some point I want to remove al of the plastic so I will get a better idea of what's going on, I will monitor it espeacially when I start riding it more.
More than anything I hate leaks as it makes the bike look crap when you see little marks under it.
Speed Blue SL 1000 Falco
- anzacinexile
