Don't throw away the little spring.
- randomsquid
- Wear the Fox Hat
Because you've lost the one that came with the second hand bit you've bought.
Yes you have.
I don't care how careful you think you've been keeping all the little bits together.
Also fishing in a wheelie bin with a magnet on a stick is cheaper than going to the fair. And there's less chance of getting knocked up by a pikey.
Yes you have.
Just done similar with a valve collet. Every single one was bagged up as it was removed from the head (16v cylynder head) After replacing all the valves i found there is one collet missing. Full shed and bin search later i still don't have it. This was only last night. So a whole weekend is wasted rebuilding the engine because i have to wait till Tuesday for the order to arrive.
Ah well, may as well do some gardening instead
- randomsquid
- Wear the Fox Hat
- randomsquid
- Wear the Fox Hat
- randomsquid
- Wear the Fox Hat
- flatlander
You have beaten up old Turk in your bedroom sounds like your getting too close to Pete ... This Turk wasn't wearing pink by any chance?randomsquid wrote:And they were in a battered old ottoman in the bedroom
- randomsquid
- Wear the Fox Hat
