underseat exhaust
cornish mafia
underseat exhaust
#1 Post by cornish mafia » Thu Feb 23, 2012 5:04 pm
Hello folks hope is all is well in the land of the falco ? Been away a bit working and not really doing a lot to the bike BUT although i've asked already does anyone know if this type of exhaust would fit on a falco with the rsvr exhaust fitted and swinging arm ...........almost won these but wasn't too sure if they would fit as i thought the battery space on the under tray may get n the way ??
Any help always appreciated ........
http://www.ebay.co.uk/itm/170786553663? ... 3D1&_rdc=1
#2 Post by blinkey501 » Thu Feb 23, 2012 5:48 pm
Yes it will fit aladinsne has this set up :smt002
#3 Post by D-Rider » Thu Feb 23, 2012 6:12 pm
This is the Hi-Level not the under-seat but it is the carbon version of what Pete has.
Don't expect a mille hugger to survive with that fitted - it bashed and burnt Pete's to death
cornish mafia
#4 Post by cornish mafia » Thu Feb 23, 2012 6:21 pm
Any photos of them fitted to Petes bke anywhere on here .....just to see what they would look like !
#5 Post by MartDude » Thu Feb 23, 2012 6:29 pm
Anyone know if Futura link pipes would fit? Not sure of the diameters, or whether they're the right length & have the right bends. But they might point you in the right direction, as it were, for a proper under-seat job. There've been some on ebay recently.
6 & 7 here
#6 Post by blinkey501 » Thu Feb 23, 2012 6:44 pm
I was at one time contemplating buying a pair of carbon can exsausts for the fazer i had has they are underseat exsausts.
Anything is possible but i would think heat shielding would be required under the battery tray and seat area of the falco...
The only other issue i could see with this set up is mounting the number plate and indicators :smt017.
I have thought about this has i have access to a pipe bender and tig welder but i have other arrangements :smt003
#7 Post by Aladinsaneuk » Thu Feb 23, 2012 7:28 pm
https://www.ridersite.com/viewtopic.php?t=6494
No chance of a hugger surviving at all - latest one lasted 50 miles!
But they do sound and perform VERY well;)
cornish mafia
#8 Post by cornish mafia » Fri Feb 24, 2012 9:05 am
Did you re-fit the original shock protector from the falco to cover the ohlins shock or does it not fit and what about the fitting of the cans to the frame ? .........sorry but you should have known by now the questions would be comiing !!!
They look smart though ,,,,,,,,
#9 Post by Aladinsaneuk » Fri Feb 24, 2012 6:22 pm
no chance of the original shock cover fitting !
best chance is too fit a shock tube - nooj sells them :)
as for mounting the cans.... surprisingly easy.... under the rear cowl there are two threaded mount points just in front of the rear light assembly - drop a straight bar down from them, and bolt the straps too them - you will have too bend the straps too the right shape
looks good - but renegades sound ... AWESOME
(Oh - they do perform well !)
cornish mafia
#10 Post by cornish mafia » Fri Feb 24, 2012 6:51 pm
All sounds good to me thanks for the help once again .........now where have i put that Visa card !!! :smt017
GregD-UK
Renegade Setup...
#11 Post by GregD-UK » Fri Feb 24, 2012 8:48 pm
OK, have a glimpse at my latest pic in the "Gallery," have the renegade setup and Two Brothers M2 cans on. Flippin so loud I came home from fitting and set off car alarms in my street (Narrow street!). Never mind, have stiffened up my suspension to keep exhaust away from my carbon hugger. Will be fitting different end caps :smt002
Recommend getting the renegade setup people :smt004 Although don't copy too much! Rang Two Brothers in California, and no R+D was done on fitting carbon cans on a twin setup on an aprilia :smt017
Guess our ride is above the norm......
Falconihlist
#12 Post by Falconihlist » Fri Feb 24, 2012 11:20 pm
I had the blue shock on when I fitted my cans, and the rear tyre was rubbing on the inside of the cans on the mounting bracket :smt009
Switched to an Öhlins which jacked up the rear end, and problem solved :smt003
Whether it be the Renegade setup or normal headers high level is bloody awesome, especially with baffles removed :smt003
Black is fastest!
#13 Post by blinkey501 » Sat Feb 25, 2012 6:01 am
I started the bike with the baffles removed on the venoms under the lean to, and the mrs was stood behind me waiting to pass....
The choke was fully open so the bike revs went straight to 4000 rpm...
Sally nearly pooed her self :smt003
cornish mafia
#14 Post by cornish mafia » Mon Feb 27, 2012 8:18 pm
BUGGER BUGGER BUGGGER...............AND ONE MORE TIME BUGGER . :smt013 Had someone on evil bay saying he'd sell me some as the german who won them hadn't paid so he said he'd re-list them for me then never sent me the number .......ALL GONE NOW .....BUGGER BIGGER BUGGER ....AND ONE LAST TIME BUGGER :smt013
Anyone got a renegade hi-level exhaust system they want to sell me .......... :smt003
#15 Post by Aladinsaneuk » Mon Feb 27, 2012 8:47 pm
Very sexy those renegades ;)
