Running lean?
Falcoholic
Running lean?
#1 Post by Falcoholic » Fri Mar 30, 2007 8:32 am
On changing the spark plugs I found the front two to be sooted up therefore running rich and the rear two to show signs of running lean i.e sandy coloured electrodes.
So what's the problem and where's the fix?
Think I know the answer but you lot can get yer post counts up by confirming what I probably already know.
:smt017
The Delicate Sound of Thunder
#2 Post by Fausto » Fri Mar 30, 2007 11:11 am
Erm... throttle body synch ?? :smt017
That's more of a guess than an expert opinion - unless it's right of course :smt003
#3 Post by Falcopops » Fri Mar 30, 2007 11:44 am
You could try putting one of the plugs that's running lean in with one that's running rich and they will ballance each other out :smt002
#4 Post by Kwackerz » Fri Mar 30, 2007 11:53 am
wheelie more. the soot will fall to the back of the engine that way. :smt002
#5 Post by HowardQ » Fri Mar 30, 2007 12:09 pm
Don't worry, now you've got the Rene air box on, you'll blow off all the soot. :smt004
#6 Post by D-Rider » Fri Mar 30, 2007 12:35 pm
Birds nesting in one of the throttle bodies?
:smt017
#7 Post by Gio » Fri Mar 30, 2007 1:09 pm
There's a gremlin hiding in there smoking :smt002
Falcoholic
#8 Post by Falcoholic » Fri Mar 30, 2007 1:12 pm
Helpful as always huh?
Thta's why I love you guys
:smt015
#9 Post by Gio » Fri Mar 30, 2007 1:22 pm
Falcoholic wrote:Helpful as always huh?
:smt015
I think you need to twist the go a bit harder and open the 2nd stage.
falcomunky
#10 Post by falcomunky » Fri Mar 30, 2007 3:28 pm
Aliens.
Its gotta be Aliens. :smt020
Two is the magic number... ;)
