Tuono top yoke and bars fit falco??????
Blackranger68
#1 Post by Blackranger68 » Sat Feb 18, 2012 2:35 pm
Probably been discussed at length before but here goes
Has anyone taken to putting on one of the newer tuono top yoke and straight bars onto a falco? Wonering if this is possible and what all would need changed?
Looking at it I would need the following:
longer cluthc and brake cables
longer throttle cables
Cut down the Falco nose cone
bar end mirrors
Anything else anyone else can suggest?
#2 Post by D-Rider » Sat Feb 18, 2012 4:37 pm
If you are talking about the newer shape Tuono, then change both top and bottom yokes as a set as they have a different offset to the old shape (which is the same as the Falco). You can force the forks in with different generation top and bottom yokes as the offset difference is small but I wouldn't recommend it.
Cut down good Falco plastics and we'll hunt you down ........ if you really must bastardise the Falco like this, please find a broken fairing and cut and repair that one ......
