Can anyone workout if these or any of the other models will work on the Falco...or will the fairing get in the way?
http://www.barkbusters.net/products/155.html
Handguards
- furygan man
The other point that might foul is on the front sub frame.
I have a definite lack of clearance there with my radial master cylinders so there might not be much room with standard master cylinders if you also fit hand guards.
- randomsquid
- Wear the Fox Hat
- furygan man
