Rear brake line fitment
I intend to change the brake lines so I have bought a Venhill rear set up.
Apart from the usual bleeding problems are there any "Falco" related problems with fitting a new line.
I don't intend to do this until the spring when I will have new pads as well.
In a way I want to check out Venhill as their product does look good, espeacially their banjo bolts which seem to allow an easier fitment.
Speed Blue SL 1000 Falco
i cannot help being popular - i get all sorts of questions - like where too find the best stilts, and which hair dye works on pubes... fortunately I have friends who have spent ages finding the answers to such questions so i can only share the love....
and if i was to replace a standard falco rear brake line, i would order a mille length to replace it..... just in case you fit the mille swinger :)
no specific falco issues btw - i would follow KZMilles guide in the aprilia tech section and i prefer to reverse bleed
Not sure about that - the biggest difference to the rear brake line length would be due to the significantly different location of the rear master cylinder on the mille.Aladinsaneuk wrote:i
Certainly the Falco line works without problem if you fit a Mille swingarm - if you want to be cautious, order a line an inch longer than standard (certainly no more than that)
I got the kit and since I was bored I fitted it to the bike, the quality of the hose and fittings is fine.
One thing though is they supply a angled banjo which is a t**t to fit to the pump, so much so in fact that I have ordered anothe rstraight fitting to replace it as I think the strain on the hose will prove to be a problem later on.
As for the bleeding of the brake I tried for a while and but got no where and then I removed the caliper and held it up and then it bled perfectly and quickly.
