Memory foam and electric blanket?
- BikerGran
- Gran Turismo
I've bought a memory foam mattress topper which is great for my arthritic hips - but now I'm puzzled about how to use my electric underblanket! Seems to me if I put it on top of the memory foam it'll negate the softness, but what will happen if I use it underneath? Anyone come across this problem?
am only going by the advice I received from an older member
and btw, many thanks for your advice - my residents were really grateful that some one of more senior years took the time to share stuff
- snapdragon
- Samray
- Double World Champion
Sounds right to me.It is perfectly safe to continue using you electric blanket, if you wish. Memory Foam is temperature sensitive and softens from your body’s temperature, the heat from an electric blanket will soften it further. You may find that too much excess heat will not allow your mattress or topper to support you correctly. Use only for short periods of time prior to bedtime and never use one whilst in bed.
