RSVR ECU
GregD-UK
RSVR ECU
#1 Post by GregD-UK » Tue Mar 27, 2007 7:49 pm
Would fitting a RSVR ECU give me the 130+ bhp that they have? Would I have to modify/adjust anything else on my bike :smt017
Just a thought.....
Warranty yeah rite!
#2 Post by HowardQ » Tue Mar 27, 2007 8:09 pm
Er No is the simple answer.
I've thought about the ECU before, but never had any clear answers on this. Then again the Milles have moved on since introduction and the Falco has stood still.
The only real difference between the Falco and the early Mille is the compression ratio, which is slightly higher on the Mille and not much else, once you've done the obvious mods. Around 2000 an American site back to back tested them on a rolling road. Both were fully de-restricted first, then they fitted some "less restrictive" cans on the Falco and the difference was only about 2 or 3 bhp, (around 118 flywheel bhp). Think this was still on the standard filter, so with a K&N or something better fittted, can't be much in it. However engines do vary a bit and might have been a better than average Falco and a not too good Mille.
Since then the Milles have moved up in power and are probably quite a bit different, so 130bhp plus will need a lot more work.
Probably different compression, throttle bodies, maybe cams and valves as well plus different ECU maps etc., but never really looked any further into it.
#3 Post by Kwackerz » Tue Mar 27, 2007 9:21 pm
You'd need a fair bit of work done to grab 130 at the wheel.
http://www.renegade-products.com/renega ... 1076523205
That thread at Renegade gives you a taste of what's needed.. see some of the dyno print comments (headwork, chip, twin cans, etc)
It's achievable but you could end up spending a lot of dosh...
#4 Post by D-Rider » Tue Mar 27, 2007 9:24 pm
The man for the mods to get big power is Exdukenut ..... come on Ex, remind us what you've done to create "The Beast"
:smt023
#5 Post by Kwackerz » Tue Mar 27, 2007 9:29 pm
That wasnt a plug for Rene btw, simply I knew where the dyno thread was!
Also note where the readings are taken from (engine and gearbox are calculated using the dyno software not physically measured, wheel is measured BUT it should be noted that not all dynos read the same, take figures as a guide only!)
