Standard Falco motor
Standard throttle bodies
Renegade chip (-12 whatever that means)
Renegade air filter/baseplate
The first run (green) is how I've been running the bike this year with an early Mille system where the headers meet early in the system). The red line is with the modded link pipe which joins the rear header to the collector. The blue line is the modded link pipe with a custom fuelling map on the PCIII.
The link pipe fills in the mid quite nicely but really benefits from having a custom map to get it just right. Just over 5bhp was found in the midrange.
Peak power is 116bhp at the wheel (the correction factor is EC, which is similar to SAE for our American friends). In terms of DIN (which many operators use) the peak is 120bhp at the wheel.
