Sticky mouse
Sticky mouse
Or rather, cursor
It's started 'pausing', if that's the right word - move it to another part of the screen , and, en route, and seems to stop to have a think for, sometimes, half a second, or sometimes perhaps two seconds.
When playing Age of Empires (I know, old hat but I like it) part way through a game it'll freeze up altogether, although the game's still running, and the only way to get out is to switch off the pooter at the mains.
The only change I've made recently was to uninstall AVG and install Avast.
The mouse is a Microsoft optical mouse, a replacement about a year ago for the original mouse.
Pooter is a Dell PC, running Vista; about 3 years old, I think.
Help, please
Help, please
- randomsquid
- Wear the Fox Hat
- Firestarter
- Twisted Firestarter
+1 for the computer, sounds like the AV software might be causing a bit of a stutterrandomsquid wrote:Is the hole in the bottom crudded up?
Have you changed the surface you're mousing on? They sometimes get confuddled by shiny.
Are you getting hard drive thrashing, fans spinning up or similar evidence of the PC working hard when the pointer stops playing?
Somewhat.randomsquid wrote: Are you getting hard drive thrashing, fans spinning up or similar evidence of the PC working hard when the pointer stops playing?
However, having just found a spare, new mouse - can't remember why I had it - and plugged it in, everything's working fine again. Out of curiosity, I'll try & cleean the old one & see if works ok.
Thanks, everybody.
- randomsquid
- Wear the Fox Hat
That'd be my guess. Far too intrusive some of it.Firestarter wrote:+1 for the computer, sounds like the AV software might be causing a bit of a stutterrandomsquid wrote:Is the hole in the bottom crudded up?
- randomsquid
- Wear the Fox Hat
- randomsquid
- Wear the Fox Hat
