Loosing clutch fluid-How many miles on a seal
So, I replaced the slave cylinder seal about 7K-8K miles ago with a new aprilia seal.
Noticed that the fluid level now drops ever so slightly over a period, seems to be weeping from the hole in the bottom of the slave cylinder.
How often should these things need replacing, is around 10K miles about right, if so I will just get a new seal & swap it out, but if they should last for 20K - 30K miles then maybe I need to be looking for another cause of excessive wear.
Ta muchly.
Ta muchly.
- flatlander
depends on the condition of the seal I suppose I mean are we talking a young healthy seal or one of those cute little white ones? ... igmc
Oh you said CLUTCH fluid I thought you meant .... and a horse would be better
Well, in my view, it ought to last longer than that.
I guess you could:
I guess you could:
- Check it was fitted OK (not suggesting any lack of skill on your part BTW but we all have the occasional mishap or something gets a little displaced on assembly without being spotted)
Look for any rough surfaces on the moving parts.
Check for the presence of abrasive crud in that area.
- anzacinexile
On a technicality, you "fourth" that .... adding even more weight to the adviceirich wrote:I third that. I've had hydraulic leaks due to scored bores from dirt in the system. Hydraulics need to be clean.blinkey501 wrote:I agree everything needs to be clean on re assembly, and no scores or burrs on the piston itself
Over 30,000 miles on the original seal with no issues yet.
- anzacinexile
