Sidestand sorted
Tonyunn
Sidestand sorted
#1 Post by Tonyunn » Thu Nov 10, 2011 7:27 pm
Just fitted a Firestorm sidestand.
Thanks to Aladinsane and DavShill, fitted the leg only as Alad suggested and drilled an new hole as Dav said to do, worked a treat.
The only stress bit was the springs, really pleased with the result bike sits at a much healthier angle.
This the original stand above.
#2 Post by flatlander » Thu Nov 10, 2011 9:03 pm
wish I could blurry find one :smt003
Falcorob
#3 Post by Falcorob » Thu Nov 10, 2011 9:44 pm
#4 Post by flatlander » Thu Nov 10, 2011 10:17 pm
I thought it had to be 2004-2007? but if not and that will do I will BIN can someone confirm please
#5 Post by randomsquid » Thu Nov 10, 2011 11:11 pm
I could buy it, fit it to mine and let you know if it would have fit.
I saw some shiny adjustable length ones on a Yank site once to fit a range of Japanese sprotbikes. No idea where now though.
#6 Post by flatlander » Thu Nov 10, 2011 11:17 pm
t6hats one aqppears to have sold whilst we were talking about it now thats a coincidence :smt017 so I think it may just be a case of searching goole for shiny big nobby thing for keep black bird going or just buying the Honda one new or the US one new
#7 Post by Aladinsaneuk » Fri Nov 11, 2011 6:17 am
iirc the honda fire blade stands are 50 quid new from a stealer.....
robbier6
#8 Post by robbier6 » Fri Nov 11, 2011 8:19 am
forgive my ignorance, but what sidestands fit?
is the issue with the standard side stand that it leans to far over?
#9 Post by D-Rider » Fri Nov 11, 2011 9:13 am
robbier6 wrote:forgive my ignorance, but what sidestands fit?
No - it's too upright, the sidestand touches down too close to the centre line of the bike and it's made of cheese.
Modified Gixer stand (ask Willopotomas on here and he'll mod one for you) or a number of honda stands work.
The US market Falco stand is also an excellent option but its bracket needs modifying to fit a european bike.
philgro64
#10 Post by philgro64 » Fri Nov 11, 2011 10:32 am
I fitted a 1998 Firestorm one and it fits fine. Didnt even need to drill the extra hole that has been discussed. Only real mod I had to do was secure a bolt to ensure the sidestand didn't retreat too far when in the 'up' position. It wasn't fouling anything but it seemed to confuse the warning light as it would extinguish then illuminate once it was fully back.
Tonyunn
#11 Post by Tonyunn » Fri Nov 11, 2011 10:41 am
For all but those who know otherwise this is what I used, a honda VTR Firestorm (not SP1 or SP2) side stand.
I used the leg only and the spring from the Honda, I tried not to drill a whole but the stand would not activate the switch, once I drilled the whole it was fine.
From putting the bike on a paddock stand to taking it off took an hour and a half.
The bike used to lean horribly and now it stands taller and the leg reaches out further away from the bike.
#12 Post by Aladinsaneuk » Fri Nov 11, 2011 11:53 am
D-Rider can actually take the sidestand off with out a paddock stand.....
#13 Post by Samray » Fri Nov 11, 2011 11:53 am
#14 Post by D-Rider » Fri Nov 11, 2011 2:14 pm
Aladinsaneuk wrote:D-Rider can actually take the sidestand off with out a paddock stand.....
It wasn't the sidestand that I was actually trying to remove ..................
I wondered how long it would take before that one was mentioned again ....
anzacinexile
#15 Post by anzacinexile » Fri Nov 11, 2011 3:20 pm
Or the engine if you want to keep the 3 bolts. MUCH stronger
