Clutch Master cylinder
Tonyunn
#1 Post by Tonyunn » Tue Nov 08, 2011 6:32 pm
After reading various bits and pieces about the heaviness of the clutch has anyone fitted one of these?
http://oberon-performance.com/acatalog/ ... nders.html
tommy
#2 Post by tommy » Tue Nov 08, 2011 7:25 pm
Got one fitted to mine. It's fandabbydoozie. Highly reccomend oberon. Nice guys
Tonyunn
#3 Post by Tonyunn » Tue Nov 08, 2011 7:35 pm
Thanks for that, is it a straight swap, the original seems to just float above the bars.
#4 Post by blinkey501 » Tue Nov 08, 2011 7:59 pm
:smt017 I do believe you could do with a tuono sprocket cover has there is no need to cut your falco one? :smt017
Re: Clutch Master cylinder
#5 Post by D-Rider » Tue Nov 08, 2011 8:03 pm
Tonyunn wrote:After reading various bits and pieces about the heaviness of the clutch has anyone fitted one of these?
errr .... that'll be the SLAVE cylinder then :smt002
Firestarter
Twisted Firestarter
#6 Post by Firestarter » Wed Nov 09, 2011 6:36 pm
Firestarter
Twisted Firestarter
#7 Post by Firestarter » Wed Nov 09, 2011 6:37 pm
Tonyunn wrote:Thanks for that, is it a straight swap, the original seems to just float above the bars.
And yes, it is a straight swap, but not for anything over the bars, it's behind the front sprocket cover!
Tonyunn
#8 Post by Tonyunn » Wed Nov 09, 2011 7:24 pm
Now I understand, cheers.
#9 Post by furygan man » Wed Nov 09, 2011 8:03 pm
i've got one, Griff fitted it/sells 'em, fits under standard cover or get the Tuno cover option if you want to show it off? Usually available on evilbay
#10 Post by flatlander » Wed Nov 09, 2011 8:34 pm
And why have bling you can't see if you have the chance to show it off !
http://www.faniq.com/blog/Arsenal-defen ... Blog-20739
#11 Post by furygan man » Wed Nov 09, 2011 9:01 pm
...it does have an affect on the 'nut' holding the bars though! :smt003
