Indicators
Indicators
I bought some after market jobbies with resistors for each indicator, I fited 4 resistors one on each indicator has per instuction, but the indicaters flash too quick. I have seen paddys display, Impressive. on how to wire up aftermarket indicators, But before i start playing with the wiring i just want to clarify one thing. I am thinking that if i remove two resistors from the rear end this will slow things down a bit? and just leave the front end with the resistors has per paddys instruction has it is
Which indicators jay - and what are they rated at?
(how many watts.... And you still have the standard falco flash unit?)
I suspect the resistors you have are for the standard Japanese electrics - and ours are different
Nod Andy
The 10 watt aprilia standards are quite different than the 23 watt ones - in the past I have changed the flasher unit to get round this - but I have also changed resistors for the same effect
