How to remove barends
keithy
#1 Post by keithy » Tue Oct 18, 2011 9:41 am
Trying to remove the falcos barends both allen bolts and bar ends just turning, is there a way to lock it so the bolt comes out ?
Cheers Keith
Re: How to remove barends
#2 Post by D-Rider » Tue Oct 18, 2011 9:55 am
keithy wrote:Trying to remove the falcos barends both allen bolts and bar ends just turning, is there a way to lock it so the bolt comes out ?
Cheers Keith
You need to hold the bar end still. This is not easy to do without damaging the bar-end - you really need something like a strap wrench (I bought some strap wrenches from Aldi for very little money - but you have to be there on the week or two they actually stock them ... which is not this week)
#3 Post by Falcopops » Tue Oct 18, 2011 10:59 am
Use a piece of rubber on the bar end and hold with grips, put the allen ey in and give it a sharp tap with a hammer.
I've used rubber gardening gloves to good effect in the past, just put them on and gripped really tight.
Good luck
#4 Post by HowardQ » Tue Oct 18, 2011 12:06 pm
I just waited for one of mine to fall off one day, (don't know where don't know why and had never noticed it loose), got home and I just did not have the bar length I thought I had. :smt017
Not a happy situation!
Then fitted my spare, holding the bar end by hand end whilst I tightened the Allen key.
:smt009 :smt003
keithy
#5 Post by keithy » Sat Oct 22, 2011 6:42 am
Got them off using a strap wrench.
Thanks
