Turn key and trys to start
Turn key and it started first time,not been ran for over a year,but did not press start button and kill switch does not work and starter motor spins all the time,any ideas
relay?
- Willopotomas
- Falcopops
Shouldn't be too bad to track down. The starter is only going to spin up if the heavy duty wires have been connected, either directly or through the solenoid, via the start button, so there's not too many wires to check.
I'd be starting at the button and working from there to the solenoid, the button has been known to be an issue and the wiring round the headstock has to cope with a lot of movement.
Have a look at the AF1 site for a wiring diagram if you haven't already got one.
Good Luck
Good Luck
