OIL PRESSURE SWITCH - LEAK
kaisermuldoon
#1 Post by kaisermuldoon » Tue Sep 27, 2011 5:29 pm
I have noticed a small drip of oil coming from the Oil Pressure Switch, it seems to be getting worse. Obviously I need to fix this as soon as possible.
I am wondering if it is as straight forward as removing the old one, drying off the threads applying Loctite and fitting the new switch.
I guess I might lose a fair amount of oil in the process.
Anyone had experienced this problem?
anzacinexile
#2 Post by anzacinexile » Tue Sep 27, 2011 9:18 pm
Happened to me - in fact that's the only thing that's failed on me in 50K miles.
Piece of piss
Remove the old, PTFE tape, not Locktite (its a taper thread), screw in new switch NOT, repeat NOT over tightening it (its a taper thread) and no, you wont loose any oil (well, maybe a drop or two but thats all)
kaisermuldoon
#3 Post by kaisermuldoon » Sun Oct 02, 2011 9:47 am
anzacinexile wrote:Happened to me - in fact that's the only thing that's failed on me in 50K miles.
Piece of piss
Remove the old, PTFE tape, not Locktite (its a taper thread), screw in new switch NOT, repeat NOT over tightening it (its a taper thread) and no, you wont loose any oil (well,1 maybe a drop or two but thats all)
Sounds straightforward, cheers for that (':smt001')
