Am I right in assuming that the signal is sent from the thermal switch on the engine to the relay on the dash and then to the fans?
Got no fans at the moment, so goin to swap a relay over and if that works, try and bypass the thermal switch.
Fans
- Falconihlist
Fans
Black is fastest!
Re: Fans
http://www.martinpoll.dk/diverse/mille% ... iagram.pdfFalconihlist wrote:Am I right in assuming that the signal is sent from the thermal switch on the engine to the relay on the dash and then to the fans?
I think page 34 of the pdf should show you.
- Falconihlist
- anzacinexile
