Swingarm on fleaby
Falconihlist
Swingarm on fleaby
#1 Post by Falconihlist » Fri Aug 12, 2011 6:42 pm
Bargain of the week if it is in good nick
http://www.ebay.co.uk/itm/APRILIA-RSV10 ... 016wt_1139
Black is fastest!
#2 Post by Kwackerz » Fri Aug 12, 2011 7:04 pm
i'd want to see the other side (which i reckon will have a dink..)
#3 Post by D-Rider » Fri Aug 12, 2011 7:08 pm
About the same as I paid for mine .... which also had the "dink" upgrade
transparent_opacity
#4 Post by transparent_opacity » Fri Aug 19, 2011 5:00 pm
D-Rider wrote:About the same as I paid for mine .... which also had the "dink" upgrade
Mine has quite a significant dink - anyone fixed one of these dinks?
#5 Post by blinkey501 » Fri Aug 19, 2011 5:35 pm
I was going to fill mine with alloy weld and grind it back, but i think it will distort the swingarm. so i am going to fill it and put a sticker over it, or i am even thinking of powder coating after it has been filled :smt003
anzacinexile
#6 Post by anzacinexile » Fri Aug 19, 2011 7:58 pm
Get yourself down to a paint supplier and get some filler designed for alloy wheel repair. Is a bugger to file and sand but its really tough and grips like shit to a blanket AS LONG as you get the lacquer off first.
I filled a small ding plus the 'orrible button welds, treated her to proper ferric oxide aluminum primer (not the crap out of a rattle tin from Halfords) and finished with bright aluminum 2 part epoxy paint. Looks like polished alli and is as tough as old nails. Mines been done for over 40K now and still looks good as new
#7 Post by D-Rider » Fri Aug 19, 2011 8:00 pm
Yes - I got it done through someone I know. They drilled a hole from the back behind the dink, knocked it out perfectly and then welded up the hole.
Proper job.
#8 Post by blinkey501 » Fri Aug 19, 2011 8:15 pm
Proper job.
Never thought of that, i like the idea defintly going to try it. :smt003
transparent_opacity
#9 Post by transparent_opacity » Fri Aug 19, 2011 11:27 pm
Proper job.
I reckon mine would show creases if I did that :smt012
transparent_opacity
#10 Post by transparent_opacity » Fri Aug 19, 2011 11:28 pm
Sounds good! Could you link me to the epoxy paint you used? That's a new one on me. My swingarm had been filled once by a previous owner, but the monkey did it with fibreglass resin and the blighter vibrated out!
#11 Post by D-Rider » Sat Aug 20, 2011 6:57 am
Proper job.
I guess that depends on the skill of the panel beater who does the job
anzacinexile
#12 Post by anzacinexile » Sat Aug 20, 2011 8:05 pm
I did this nearly 5 years ago and I cant remember last week :smt017
Get to a paint supplier and he'll put you right. All I remember it was nothing special, all suppliers will stock it
