head bearings?
ReggieGasket
head bearings?
#1 Post by ReggieGasket » Tue Aug 09, 2011 7:01 pm
I seem to have gone my whole motorcycling life without head bearing problems (only my own), so don't really know much about them. I've noticed some looseness under normal braking. I'm assuming this is a head bearings problem? Can they be tightened or will they be knackered? Is it dangerous until I get it fixed? Thanks for any help, G
#2 Post by DavShill » Tue Aug 09, 2011 7:42 pm
Hi Reggie - not sure how easy it is on the Falco but just made some adjustments to the headbearings on my son's GSX750. He noticed "clunking" when braking and riding over bumpy surfaces. Just tightened them up to take out the slack for now becuase replacing them is a bigger job and they are not too bad yet.
Suggest you get to know Ray at RM Motorcycles on Flemingate in Beverley. Ride in and let him have a look, very friendly guy and he'll give you an honest opinion.
#3 Post by D-Rider » Tue Aug 09, 2011 10:09 pm
See the workshop manual section 2.28.2 :smt004
#4 Post by HowardQ » Tue Aug 09, 2011 10:17 pm
Tightening them up a bit may help as Dave says, but they are not taper bearings so if worn, it is down to replacement I'm afraid.
Sadly the Falco is prone to wheelie on odd occasions :smt002 :smt002
(but less likely in 4th gear upwards!) and heavy landings can bring problems.
anzacinexile
#5 Post by anzacinexile » Wed Aug 10, 2011 7:26 am
HowardQ wrote:Tightening them up a bit may help as Dave says, but they are not taper bearings so if worn, it is down to replacement I'm afraid.
Ermmm - not strictly true
They're not taper but angular contact bearings so adjustment is possible and indeed, recommended. As D mentioned, para 2.28.2 shows how and it ain't difficult
#6 Post by HowardQ » Wed Aug 10, 2011 11:53 am
But as you quote, I did say tightening them up a bit may help.
ReggieGasket
#7 Post by ReggieGasket » Wed Aug 10, 2011 4:22 pm
Thanks guys :smt003
