most likely cause of losing the horn
#1 Post by flatlander » Thu Jul 28, 2011 7:08 pm
No really :smt002 the horn stopped working today
#2 Post by Nooj » Thu Jul 28, 2011 7:16 pm
Has the wire worn through? Mine did, didn't find out about it until I pressed the button and lost all power to the dash and lights as the fuse blew.
can't see any sign
#3 Post by flatlander » Thu Jul 28, 2011 7:21 pm
and everything else is fine I'll go and check again thanks
#4 Post by D-Rider » Thu Jul 28, 2011 7:42 pm
This thread covers the cause (and solution) when mine stopped working: https://www.ridersite.com/viewtopic.ph ... light=horn
Firestarter
Twisted Firestarter
#5 Post by Firestarter » Thu Jul 28, 2011 8:48 pm
Mine went, and it was... a broken horn. Replacement job for me
hey Salty
#6 Post by flatlander » Thu Jul 28, 2011 9:40 pm
are you out next week weather being good an all ?
dyzio
#7 Post by dyzio » Thu Jul 28, 2011 10:46 pm
Firestarter wrote:Mine went, and it was... a broken horn. Replacement job for me
Same here
#8 Post by D-Rider » Thu Jul 28, 2011 10:51 pm
My initial assumption when mine stopped working was that it was the horn itself .... but it wasn't.
I've still got the replacement one I bought but didn't need ..................
#9 Post by Falcopops » Thu Jul 28, 2011 11:35 pm
I found mine dangling by its wires at the weekend, the hanging bracked had sheared, still worked though.
I changed it for the one off the other Falco in the garage, and when I tried it the bike died :smt017 Must be a shorting wire some where, but didn't have time to look into it.
TBH I don't think I've used the horn apart from passing tests so no drama, just leave it alone.
me too
#10 Post by flatlander » Fri Jul 29, 2011 6:29 am
just that I am sooooo happpy with my bike I want to be nice to it :smt003
#11 Post by randomsquid » Sun Jul 31, 2011 12:17 pm
I had one rot from the inside out and one that was just corroded spade ends. Bought an Accumen louder jobby that is louder but still not loud enough.
The on my mates old Trumph stopped working when it fell off on the motorway and smashed into the front of my bike.
#12 Post by MartDude » Sun Jul 31, 2011 4:36 pm
Get a flip-up helmet. Then you can shout more effectively
#13 Post by randomsquid » Mon Aug 01, 2011 5:19 pm
MartDude wrote:Get a flip-up helmet. Then you can shout more effectively
Or you could raise that staff and zap them with blinding white light.
roosterNI
#14 Post by roosterNI » Tue Aug 02, 2011 12:27 pm
my horn stopped working, t'was the wire inside the switch had wobbled off, just re soldered it and job done.
Re: most likely cause of losing the horn
#15 Post by furygan man » Tue Aug 02, 2011 3:41 pm
flatlander wrote:No really :smt002 the horn stopped working today
...alternatively...
