Tried to remove mudguard, snapped two of four bolts. Tried to remove front wheel, one snapped bolt of the four. All parts removed, all bolts drilled out and threads chased.
Now the forks are off I sent them for a long overdue service (>4 years since last oil change) at Peak Performance.
Thing is, Steve says the rod from the rebound adjuster down to the bottom of the forks has snapped on one side, so effectively no rebound damping on one leg. No wonder they felt to bad!
Anyone had any issues with this? Got any solutions? The part number is AP8123830 I think, and £300 new (!) Can get a complete set of forks for ~£350, or refurb'd Ohlins for £550.
He's going to try and fix the break, but slightly annoyed. Falco is the perfect bike for me, but I don't think there's a bike on the planet that is straightforward once it gets past 10 years old.
Fork problems
- Falco9
I appreciate that you are using Peak to service the forks but Gareth @ Reactive Suspension in York has been re-valving and servicing these Showa forks for years.
http://www.reactivesuspension.com/
It might be worth giving him a ring to see if he has any spare parts if you have no joy obtaining the parts elsewhere
F9
F9
