'C' Spanner
'C' Spanner
#1 Post by furygan man » Thu Jun 30, 2011 3:30 pm
Anywhere on the 'high street' you can get these or is it mail order only, just been into Halfords and no joy?!!...and what the size i need to fit the 'yellow spring' shock nut?
One more thing, i have a nut that keeps working it's way loose on my mirror- did i read on here something you can spray on or add to the thread to stop this??
paddyz1
#2 Post by paddyz1 » Thu Jun 30, 2011 3:46 pm
Change the nut for a new nylock nut or put some thread lock on
#3 Post by furygan man » Thu Jun 30, 2011 3:48 pm
paddyz1 wrote:Change the nut for a new nylock nut or put some thread lock on
...that's the stuff- i take it's freely available from B&Q or alike?
thanks Paddy
#4 Post by Willopotomas » Thu Jun 30, 2011 5:13 pm
BnQ.. you'll be lucky to find anything you need in that place mate. You'll be better off heading down to your local motor factors or engineering supply shop.
As for the c-spanner.. I'll make you one. If it's the same as Ohlins shocks, I already have the CAD as I made Mr Rider a couple about a year ago. :smt001
#5 Post by furygan man » Thu Jun 30, 2011 5:24 pm
Willopotomas wrote:BnQ.. you'll be lucky to find anything you need in that place mate. You'll be better off heading down to your local motor factors or engineering supply shop.
A) easier said than to find!!
B) that would be good if you have the time mate?
#6 Post by MartDude » Thu Jun 30, 2011 5:59 pm
Re 'A' ; plenty of suppliers on ebay/Amazon - where I got my last lot, being some distance from nearest engineers' merchants
snapdragon
#7 Post by snapdragon » Thu Jun 30, 2011 7:04 pm
thread lock often in halfrauds, or local motor parts shop, C wrench = hammer and long cold chisel/heavy drift
Snappy ~~X~X~{:>
#8 Post by furygan man » Thu Jun 30, 2011 7:04 pm
snapdragon wrote:thread lock often in halfrauds, or local motor parts shop, C wrench = hammer and long cold chisel/heavy drift
...is the last bit some kinda code :smt017
snapdragon
#9 Post by snapdragon » Thu Jun 30, 2011 8:06 pm
furygan man wrote:...is the last bit some kinda code :smt017
:smt003 lol yup, it's code for sod the C 'spanner' get a big metal stick, place against the crennelations on the adjusting 'crown' (crennelated ring) and hit the other end with a hammer
:smt001
Snappy ~~X~X~{:>
#10 Post by furygan man » Thu Jun 30, 2011 8:07 pm
:smt001
:smt005
#11 Post by D-Rider » Thu Jun 30, 2011 8:42 pm
Will does make a mighty fine C-Spanner .... very happy with mine :smt004
I tend to buy my loctite from ebay as the car parts shops tend to charge the earth (as do some ebay suppliers)
#12 Post by Nooj » Thu Jun 30, 2011 9:16 pm
Can do this for £9.50 for a 10ml bottle (takes ages to use up). How does that compare to what's on e-bay?
Loctite® Threadlocking, Nutlock 243
Medium strength oil tolerant torque tension grade
General purpose threadlocking
Particularly suitable for less active surfaces e.g. stainless steel
Prevents loosening through vibration and leakage of threaded fasteners
#13 Post by D-Rider » Thu Jun 30, 2011 9:48 pm
Nooj wrote:Can do this for £9.50 for a 10ml bottle (takes ages to use up). How does that compare to what's on e-bay?
Well you did ask .......... http://cgi.ebay.co.uk/loctite-243-1-X-1 ... 3f0b656f1c
Sorry :smt053
I think I bought a 50ml bottle the last time I needed some
#14 Post by Nooj » Thu Jun 30, 2011 10:44 pm
Holy crap!!
#15 Post by furygan man » Fri Jul 01, 2011 8:15 am
Sorry :smt053
:smt003 you got in there first DR, thanks will get some ordered
Hey Will :smt024 ....can i have a C spanner please???? :smt026
