Possible Mid Section Production Run...
GregD-UK
#1 Post by GregD-UK » Tue Jun 28, 2011 11:24 pm
OK then, might get my exhaust chap to do the "upgrade" on the mille mid section. This upgrade also negates the requirement for you to buy mille oil tank and re-route any pipe-work et etc...
This particular re-augmention will utilize the falco standard front header pipe. It doesn't impinge on the falco oil tank also, before anyone asks :smt002 So, you can gain mid-range torque and some top-end apparently, going off the information flying about on here. Also, you only need to buy one can. Or you can see by the previous mid-section thread, a shotgun setup is feesible :smt003
Ultimately, price is dependant on numbers. Also, I have to give him mine and he will have to make a jig. Ball-park figure is £120 plus p+p. Turn around time would be dependant on numbers and demand. Probably a week I guess.
Let me know if anyone is interested....
#2 Post by D-Rider » Wed Jun 29, 2011 8:37 am
just to add a pic etc - this is what Greg posted up previously about this mod.
GregD-UK wrote:Hi all,
OK, first stage completed. As you can see, I have got the mille med-section to link to the falco front header pipe. Saves changing the oil tank, redo pipework etc (Unecessary cost, time, and effort!).
Basically it adds the balance pipes that give the mid range boost to the Mille system but re-routes the line of the front cylinder exhaust to mate with the Falco front header ... avoiding the need to change the oil tank and oil cooler.
Neat solution
(I'm in for this one BTW) :smt004
Olig7475
#3 Post by Olig7475 » Wed Jun 29, 2011 1:54 pm
Hey Greg, you can put me down for one as long as it doesn't go up much more than what you've quoted!!!
I fancy having the single exhaust setup without the hassle of making all those changes, also if I don't like it I can revert back to the original set-up :smt003
GregD-UK
#4 Post by GregD-UK » Wed Jun 29, 2011 8:03 pm
That's deux then, so far...
We shall leave it on here till end of the month. Take numbers then decide if it worth getting it off the ground folks :smt004
#5 Post by Viking » Thu Jun 30, 2011 12:12 am
I like the idea of this mod (and it looks pretty shiny!). However, I really do prefer the "balanced" look of the twin exhaust.
If you were to make a twin-can version of this, I would be interested.
#6 Post by Aladinsaneuk » Thu Jun 30, 2011 5:35 am
erm viking.... twin cans will fit there....
any of the early mille twin can set ups will fit on that - my renegades would for example....
#7 Post by furygan man » Thu Jun 30, 2011 8:12 am
Aladinsaneuk wrote:erm viking.... twin cans will fit there....
Ah that's interesting, so would it be if we went down this route that we could buy Mille hi level set up that would look similar to yours Pete? So buy these pipes and there's nothing else to change apart from link pipes and end cans
The only current hi level i know available for Falco are GPR, would doing this mod offer a few more alternatives? If so then i'm in too, remember replies in 'CBeebies' speak please i'm not very good a to keeping up with the 'techno' waffle :smt003
#8 Post by Aladinsaneuk » Thu Jun 30, 2011 10:38 am
Yes... You would have more choices
Only caveat is the mounts would be different - there is an easy solution involving two short lengths of metal plate from the falco rear subframe - the mounts already exist on the subframe hidden under the rear cowl
#9 Post by Aladinsaneuk » Thu Jun 30, 2011 11:35 am
Just to add - some people have said that some Mille twin pipes will not work with a falco swing arm - I have seen it done... With high mounts you should not have a problem though
#10 Post by furygan man » Thu Jun 30, 2011 11:50 am
Aladinsaneuk wrote:Just to add - some people have said that some Mille twin pipes will not work with a falco swing arm - I have seen it done... With high mounts you should not have a problem though
Haven't been able to locate any highmounts for mille
#11 Post by D-Rider » Thu Jun 30, 2011 1:03 pm
Indeed - Mille 2:1:2 pipes are rare.
I do have a set I could be prepared to release - but both cans are on the same side of the bike ..... and they are not hi-mount ........
#12 Post by furygan man » Thu Jun 30, 2011 1:41 pm
ah well, count me out then
#13 Post by Aladinsaneuk » Thu Jun 30, 2011 5:42 pm
I would look in the for sale section of af1 and try aprilia performance forums. There were two sets there recently
#14 Post by Viking » Fri Jul 01, 2011 1:40 am
Any of the early mille twin can set ups will fit on that - my renegades would for example....
Maybe I'm being a bit dense here. I meant "one can on each side of the bike, as per the stock Falco exhaust setup." If I can't keep my existing SL Carbon cans, then I'm not really interested any more.
#15 Post by D-Rider » Fri Jul 01, 2011 8:10 am
Pete's setup has one can each side - following the 2:1 mid section, his pipes split into 2 again - though it does lead to exhausts tubes of significantly different lengths.
The mod is primarily for those of us that prefer the less cluttered look (and wider choice of cans) of a 2:1 setup - or a set of shotguns.
