Cheap shock upgrade
The Mad Hatter
Cheap shock upgrade
#1 Post by The Mad Hatter » Sun Jun 26, 2011 11:16 am
http://cgi.ebay.co.uk/APRILIA-RSV1000-M ... 1e64b042b4
Seems like a cheap option. Sure they fit someone may correct me.
FlyingKiwi
#2 Post by FlyingKiwi » Sun Jun 26, 2011 11:38 am
You'll need the Dogbone and Tri angles with that one (although someone is bound to point out that it has been fitted without them :smt014 )
The White one is a straight fit.
FK
#3 Post by D-Rider » Sun Jun 26, 2011 12:13 pm
Good price ... but, yes, linkages needed.
If I were after one I'd be tempted to grab it and then keep an eye out for the linkages.
#4 Post by Samray » Sun Jun 26, 2011 12:48 pm
It's from a breaker ... he may have them too.
The Mad Hatter
#5 Post by The Mad Hatter » Sun Jun 26, 2011 2:40 pm
D-Rider wrote:Good price ... but, yes, linkages needed.
Thought that myself if anyone was after one.
Dont need it myself now I have fitted the Gen II swing arm and shock.
er me and a few others
#6 Post by flatlander » Sun Jun 26, 2011 10:20 pm
so off to bed but thtanks will look tomorrow and bug y'all for the rest of the list when the americans go
its all yellow
#7 Post by flatlander » Mon Jun 27, 2011 6:17 pm
Ok bought that one so what next ? I have asked them for the linkages and dogbone now where do I store them in the garage and stare at them or the sensible questions count too :smt005
ps
can't ruddy stand coldplay
#8 Post by Aladinsaneuk » Mon Jun 27, 2011 10:51 pm
you arrange to borrow an abba stand and a torque spanner - or pop round some ones and get it sorted
i think I fitted PhilH's new shock and linkages in around 35 minutes....
well I have been promised the links
#9 Post by flatlander » Tue Jun 28, 2011 11:03 am
and the dogbone and a willing volunteer is obviously next on my list
I am resisting obvious puns about Abba and stands
Re: well I have been promised the links
#10 Post by D-Rider » Tue Jun 28, 2011 11:26 am
flatlander wrote:and the dogbone and a willing volunteer is obviously next on my list
An Ulti-Pro stand will also be a good choice for this job
#11 Post by HowardQ » Tue Jun 28, 2011 12:01 pm
As long as you know somebody who has one, because sadly, they do not make them any more.
which brings me to an obvious question
#12 Post by flatlander » Tue Jun 28, 2011 2:02 pm
well maybe not obvious but reading other threads I gather that paddock stands may be an issue with the wheel spacer on the front is this correct or should virtually any set work ? thanks
#13 Post by D-Rider » Tue Jun 28, 2011 3:29 pm
To change the shock you need a stand that lifts from the swingarm pivot - not the end of the swingarm.
Failing that you will need to improvise to support the bike in a way that leaves the swingarm free
The Mad Hatter
#14 Post by The Mad Hatter » Tue Jun 28, 2011 6:00 pm
I did mine using a paddock stand and then its a very slight lift to put the pegs on to axel stands then very carefully remove the paddock stand.
#15 Post by D-Rider » Tue Jun 28, 2011 9:17 pm
The Mad Hatter wrote:I did mine using a paddock stand and then its a very slight lift to put the pegs on to axel stands then very carefully remove the paddock stand.
But the pegs are spring loaded ..... don't they just fold up ?
:smt017
