Rear Brake...again!
Midnight Rider
Rear Brake...again!
#1 Post by Dalemac » Thu Jun 23, 2011 2:45 pm
Hi Guys,
My rear brake is playing up again, so i have decided to relpace the disk and thoroughly clean and reassemble the caliper.
The rear disk will not come off the wheel. i have removed the bolts from the wheel and cleaned it thoroughly, and even lightly apped it with a tubber hammer, but the thing will not budge. i guess it has siezed itself on through extreme heating and cooling.
Any ideas how i can get it off?
thanks,
Dale
Falco9
#2 Post by Falco9 » Thu Jun 23, 2011 2:50 pm
Bigger Hammer...............Seriously.
Have a go through the spokes of the wheel using the shaft of the hammer against the disc in a 12 6 9 3 pattern. They do get stuck on but a decent knock should get it off. Its down to the different metals corroding toegether. Steel & alloy is not a good long term mix.
F9 :smt006
PS Whats a tubber hammer?? :smt005 :smt005
Midnight Rider
#3 Post by Dalemac » Thu Jun 23, 2011 3:09 pm
lol, meant a rubber hammer.
will try again, hopefully get the damn thing off
Midnight Rider
#4 Post by Dalemac » Thu Jun 23, 2011 3:15 pm
ok its off :)
thanks for the advice, dont know why i didnt think to hit it harder. Guess itsa not my most used tool :P
FlyingKiwi
Re: Rear Brake...again!
#5 Post by FlyingKiwi » Thu Jun 23, 2011 3:45 pm
Dalemac wrote: and even lightly apped it
Did you use an Android App or an apple One :smt017
Midnight Rider
#6 Post by Dalemac » Thu Jun 23, 2011 4:40 pm
wow, didnt realise the spelling police were on patrol today!
oh and i would never use anything apple. they are worse than sony!
#7 Post by Samray » Thu Jun 23, 2011 4:46 pm
I'll not mention the other two misspeelings then. :smt002
Midnight Rider
#8 Post by Dalemac » Thu Jun 23, 2011 5:30 pm
Samray wrote:I'll not mention the other two misspeelings then. :smt002
my hands are filthy, im typing using one finger per hand, probably why i am not spelling very well!
#9 Post by Willopotomas » Thu Jun 23, 2011 5:37 pm
*coughs* bullshit *coughs* :smt003
My advice would have also been to find a larger hammer. But yer sorted now, so wotevva.. :smt001 :smt016
Midnight Rider
#10 Post by Dalemac » Thu Jun 23, 2011 6:06 pm
Now i cant get the one of the fking pistons out the rear caliper, even after splitting the caliper into two. i guess this could be the cause of the sticking brake. if i ever get it out, its definately going to be new seal time
#11 Post by Willopotomas » Thu Jun 23, 2011 6:55 pm
I usually try to get the pistons part of the way out while they're still connected. Easy enough to do.. ye just have to alternate which piston you stop moving forward. :smt001
Midnight Rider
#12 Post by Dalemac » Thu Jun 23, 2011 7:17 pm
Willopotomas wrote:I usually try to get the pistons part of the way out while they're still connected. Easy enough to do.. ye just have to alternate which piston you stop moving forward. :smt001
yeah i got one out completely, the other one is about 1/3 of the way out. Gonna have to go and buy one of those piston remover forecep style things.
Dale
#13 Post by Willopotomas » Thu Jun 23, 2011 7:21 pm
na ye not. glorified pair of mole grips. if you're careful, you'll be able to get a decent enough grip to wriggle the blighter out. don't use heat as it'll be pointless. if you've got access to a good supply of compressed air, i've had them pop out using it before now.. bit hit n' miss though.. ye need a good seal and the pressure isn't always enough.. depends how stuck it is. :smt001
Midnight Rider
#14 Post by Dalemac » Thu Jun 23, 2011 7:23 pm
Willopotomas wrote:na ye not. glorified pair of mole grips. if you're careful, you'll be able to get a decent enough grip to wriggle the blighter out. don't use heat as it'll be pointless. if you've got access to a good supply of compressed air, i've had them pop out using it before now.. bit hit n' miss though.. ye need a good seal and the pressure isn't always enough.. depends how stuck it is. :smt001
yeah but the last thing i need is to damage the poston! no compressed air unfortunately :(
#15 Post by Willopotomas » Thu Jun 23, 2011 7:29 pm
if you take care, you wont damage the piston. Grip on a part that doesn't got past the seal. :smt002
