I know it's sad but.....
#1 Post by BikerGran » Fri Jun 17, 2011 2:25 pm
I play Spider Solitaire to relax and wind down - quite a lot!
Now it's lost its sound, and it's just not the same without the sound effects!
No, I've tried that - the sound effects ARE turned on, and I've tried turning them on and off again.
Sound is ok for other stuff, just this...? Have I worn it out?
Edit - correction, some of the sound effects don't work - curiouser and curiouser!
#2 Post by Samray » Fri Jun 17, 2011 3:12 pm
Take your ear plugs out? :smt020
#3 Post by BikerGran » Fri Jun 17, 2011 3:19 pm
Gee thanks!
#4 Post by Falcopops » Sun Jun 19, 2011 2:16 am
TURN YOUR HEARING AID ON!
:smt016
#5 Post by Kwackerz » Sun Jun 19, 2011 8:47 am
If it only happens for spider solitaire, i'd suggest reinstalling it.
*edit*
just did a bit of snooping.. try this:
http://www.ehow.com/how_6325327_trouble ... ws-xp.html
#6 Post by BikerGran » Sun Jun 19, 2011 10:57 am
Cheers K, may have a go at that when I'm feeling strong - odd thing is it's working atm - seems to come and go!
#7 Post by MartDude » Sun Jun 19, 2011 7:57 pm
I find the sound rather irritating - better without it.
Perhaps it's a girlie thing?
Try messing with WMP
#8 Post by flatlander » Fri Jun 24, 2011 11:23 am
I would suggest you to first try playing some music from windows media player to check if all your sound settings are set correctly and then try playing sound from spider solitaire.
It may be that you need to update WMP can't recall if you said you had XP but sometimes helps after upgrades to OS and at elast downloads newer Codecs (info for sound files)
#9 Post by BikerGran » Fri Jun 24, 2011 4:45 pm
MartDude wrote: Perhaps it's a girlie thing?
Perhaps it is! I like the beeps of electronic games too, and fireworks that go 'wheeeeeee' !
And I'm pleased to know I'm not the only one who plays it!
Strangely the problem seems to have gone away. :smt017
