trading up from a TDM 850......but!
Hi, I'm selling the TDM and am after a Falco for about 2500 quid. I think I can live with the reported iffy rear shock, can probably persuade the girlfriend that the tiny seatpad will be ok for a bit of touring and can hopefully resist the temptation to travel MUCH faster.........BUT, my personal pet hate on a bike is poor low-rev fuelling, so I wonder if this means the Falco is not the bike for me?
Many thanks in anticipation
Welcome
The rear shock - and side stand are the only two things I would change....
The rear saddle is ok - unless your girl friends bum is bigger than hanna's fat arse
The bike pulls well - flat spot at low revs ... Ish
Oh - speed wise it will pull a genuine 150 in stock unrestricted trim
Ride one - then decide - it remains the best all round bike I have ever had
- FlyingKiwi
Again welcome and ignore himAladinsaneuk wrote:Welcome
- HowardQ
As others have said, it is a great all round bike.
I have had dozens of bikes over many years and it is the best one I have ever had, that's why have had it almost 7 years and won't be getting rid any time soon!
Low speed running is no different from any other V Twin, probably better than most and not too different from your TDM.
To do smooth low speed U Turns, it is better if you slip the clutch to control speed rather than trying to get the throttle perfect a low revs. Then again that's the recommended way for any bike.
General fuelling is good.
Lowering the gearing by going from a 16 tooth to a 15 tooth front sprocket helps smoother low speed moves and is one of the best mods you can do for the bike, (after the side stand!).
A simple test ride is not always easy, especialy for someone like me, who had spent years on Jap 4 cylinder bikes. It was very diffferent from a 4, but I did like it a lot on the test drive and we grew together more over the next month and 1000 miles.
I think you will like it!
Take a ride on the Dark Side
same as what everyone has already said, you’re not likely to get a bad review of the bike on this website, but honestly it’s a fabulously involving bike, quite lot of vibration and low down revs are a bit lumpy, but it’s a big V Twin you’re always going to get that and that’s what makes it such a great bike. When you get to your destination you feel like you’ve been on a bike and you’ll have a great big smile on your face. Once you get used to it, it's one addictive bike to ride, all that lovely torquey grunt that rockets you to the red line (if your brave enough to rev it that far) it will pretty much keep up with anything modern on the open road. Get one you wont regret it
With all my previous bikes, my mates used to comment that an on-off switch was all I needed - full throttle or braking for the bend.Aladinsaneuk wrote:and if you fancy a real challenge, swop the throttle for an on/off switch - saves time :)
It was a bit unfair as I also had a "town" throttle position.
Falco is a bit to brutal for that though.
