New Hard drive Help
FlyingKiwi
New Hard drive Help
#1 Post by FlyingKiwi » Tue Mar 20, 2007 7:22 pm
Ok Techies!
My sons 'puter stopped working.
Took it to a local PC shop and they want £90 to replace the faulty Hard Drive.
Now, seen as I can get an 80gb HDD for about £ 35 - 40 I'm thinking of doing it myself. Only problem is I've never done one before .
How hard will it be? :smt017
I'm not worried about losing info, it was only a 7 year olds play PC.
Do I need a SATA,or an IDE,or a PATA,or an ATA or a whatever Hard Drive?
Samsung, Maxtor, IBM, Does it matter?
New or Re-furbished?
Any advice welcome
FK
#2 Post by Kwackerz » Tue Mar 20, 2007 7:27 pm
http://www.fonerbooks.com/r_hard.htm
Picture paints a thousand words..
Swap HDD,
Reinstall XP or whatever's on it,
Job's a Fish!
#3 Post by Kwackerz » Tue Mar 20, 2007 7:35 pm
I just troll into PC Worms,with the old un, grab an oik, let them run about finding you various suitable HDDs before making a choice based purely on which one is cheapest and biggest!! :smt005 :smt005
FlyingKiwi
#4 Post by FlyingKiwi » Tue Mar 20, 2007 7:37 pm
Actually, that's what I was hoping was gonna happen here :smt003
#5 Post by Kwackerz » Tue Mar 20, 2007 7:51 pm
'go for the cheapest and biggest'
There. Sorted :smt002
Re: New Hard drive Help
#6 Post by Gio » Tue Mar 20, 2007 8:55 pm
FlyingKiwi wrote:Ok Techies!
Any advice welcome
FK
One advantage is you can specify what needs putting on it, they will also make sure its working at optimum (well the ones I know do) plus the guarantee, anything goes wrong in the 1st year they have to sort it. IMO £90 is cheap.
#7 Post by Kwackerz » Tue Mar 20, 2007 9:08 pm
Working at optimum? How'd they do that then?
If you pay 40 quid for what physically takes 15 minutes, more fool you!
Swap HDD : 2 minutes.
Turn on, Insert Windows Disc 1 minute
Press a few keys, 2 minutes
*goes for brew or two*
Come back: spend 12 minutes registering windows.
Where's the hardship there?
Warranty? Manufacturers warranty is a year as it is?! That's all a shop'd use to recoup a new HDD.
#8 Post by Fausto » Wed Mar 21, 2007 3:38 pm
I did this very operation over Xmas. Now whilst it is definately not as easy as Kwackerz makes out - well not for me anyway - it is certainly a DIY job especially if you have ever reinstalled an Operating System before.
I got an 80 GB HD for about £30 from E Buyer.
There are lots of step by step guides on the net - it helps to have another pooter online as you do it so you can refer to guide if in doubt.
Watch for static - use a strap to be xtra sure. Remove old HD noting which plug on which cable it hooks up to. Should be 2 cables - 1 for power and the big flat one for data. Note how jumper is set and set new HD the same.
Format the new drive - good time to opt for a partition if you haven't already. Install Windows.
That's meant to show how easy it is but not a full and comprehensive guide :smt002
FlyingKiwi
#9 Post by FlyingKiwi » Wed Mar 21, 2007 4:10 pm
Hey Hey, Job Done :smt003
easy peasy and only cost £33 for the drive and £15 for the initial fault finding.
Now If I don't tell "Her in doors" I can spend the £47 difference from the shop on some Falco Bling :smt077
#10 Post by Samray » Wed Mar 21, 2007 4:34 pm
Well fettled. :smt003
#11 Post by Fausto » Wed Mar 21, 2007 5:06 pm
Well done !!
Now what can you get for £47 ?
FlyingKiwi
#12 Post by FlyingKiwi » Wed Mar 21, 2007 5:43 pm
Not a lot :smt012
#13 Post by D-Rider » Wed Mar 21, 2007 6:00 pm
I often buy from eBuyer but think you were done this time (well only a little bit).
My PC is now running with half a Terrabyte - 2x 250 GB drives from Aldi .... if I remember they were about £50 or £60 each.
They are Western Digital Caviar as well
:smt004
FlyingKiwi
#14 Post by FlyingKiwi » Wed Mar 21, 2007 6:25 pm
My son's was a Cybermaxx PC from Toysrus, which is a Medion computer, who do the Aldi computers.:smt017
It was a Seagate drive, only a couple of yrs old which went pop.
