new shock
- Falconihlist
new shock
After a discussion with swmbo, I've got the go ahead to get a new shock. The catch is it has to be no more than 400 quid, so do I go with Nitron or Hagon? I know that I could go with a refurbed Ohlins or white spring Sachs, but for the cost of getting a refurb, I might as well get a new one. Any thoughts?
Currently with the Nooj getting the bike cleaned for the first time ever!
Black is fastest!
- Falconihlist
- Falconihlist
place in scotland is the best place i believe
PhilH had his done there and rated it
I will post up later with a contact for you
(And doing that means even more for the trouser fund....)
- Falconihlist
- HowardQ
My first choice would be as Pete suggests, if you go for one of the other two I would probably go for the Nitron. I have a mate who is very happy with his. The only Hagon shocks I have experience of were old twin shocks and the Hagons in those days were good budget options compared with new pukka parts. Hagon's current mono shocks are quite good I believe, but a bit basic.
Strangely I have never seen a write up on one in any bike mag.
Take a ride on the Dark Side
A few comments from Futura owners with experience of Hagons
http://www.apriliaforum.com/forums/show ... ight=hagon
- snapdragon
searching for shock related stuff turned up a refurb place near Kingsclere Berks, know of them? I'll look again if it's any use to youFalconihlist wrote:Further to that then, does anyone know the best place to get whitesprings serviced? There's now two of us wanting to get this done in the Berkshire area.
Snappy ~~X~X~{:>
- furygan man
http://www.revsracing.co.uk/aboutus.php
I and others have used these so they are used to Sachs/Falco folk. post it to them and they'll post it back or ride up to Brum and they'll fit/set it up for you as part of the deal, two guys run it, friendly blokes
- back_marker
Spoke to a chirpy Brummie at Revs Racing earlier, rebuild will cost around £100 with VAT and he'll fit a recessed valve as well. Sounds pretty good to me, is that about the going rate?
- Steve McQueen
- Steve McQueen
- furygan man
sounds about right, they'll be cheaper and more expensive quotes around but at least you know these guys come recomended. I had the Yellow shock Sachs serviced + replacement spring to match my weight in full gearback_marker wrote:Spoke to a chirpy Brummie at Revs Racing earlier, rebuild will cost around £100 VAT and he'll fit a recessed valve as well. Sounds pretty good to me, is that about the going rate?
