IRL: 54mm Throttle bodies (not Evoluzione)
banjaxxed1
#1 Post by banjaxxed1 » Wed May 18, 2011 7:30 am
Had these made up from some spare stock 51mm I had kicking about
http://s813.photobucket.com/albums/zz56 ... %20Bodies/
One set is stamped -
6261-560
ZB01-B
The other is stamped -
6261-560
ZB01-B - ScF
Think they are off RSVs(open to correction), they will fit all the Falcos, RSVs, Tuono V990s from 98-2003 (& maybe Tuonos to 2005 - please check if you're not sure on your model)
Features -
Low idle adjustment designed/tested
Repositioning of the bleed hole
Slotted countersunk screws replaced with stainless hexagon countersunks
1mm brass to avoid butterfly 'flutter'
Angled the bottom of the bore into the original cast bore
Butterflies .001 of an inch clearance - metric it is .025mm cut on 4th axis mill
Custom red-anodized velocity stacks
Euros €250 + shipping includes velocity stacks & what you see - fuel pressure regulator, throttle body sensor, idle adjusters etc
#2 Post by Nooj » Wed May 18, 2011 12:22 pm
They should fit all the rotax motors from the old shape bikes baring the last special editions of the Mille (Edwards rep. + Haga rep. possibly had 57mm??) RSVR '04 onwards and Tuono '06 onwards definitely had 57mm.
banjaxxed1
#3 Post by banjaxxed1 » Wed May 18, 2011 12:37 pm
thanks Nooj, sounds right
what I wasn't sure about was Caponords & Futuras
Falco Tuonos & RSVs using the older 990 motor are good for this though yep
banjaxxed1
#4 Post by banjaxxed1 » Wed May 18, 2011 3:06 pm
#5 Post by MartDude » Wed May 18, 2011 5:52 pm
Not Capos or Futuras
#6 Post by mangocrazy » Wed May 18, 2011 8:56 pm
To the esteemed Mr banjaxxed1...
Sir,
You have pm... :smt003
#7 Post by Aladinsaneuk » Wed May 18, 2011 8:57 pm
Lol....
You will be painting it blacker....
#8 Post by D-Rider » Wed May 18, 2011 9:00 pm
They look good ..... but I've already got some 54s sitting in the garage waiting to be fitted.
#9 Post by Aladinsaneuk » Wed May 18, 2011 9:20 pm
You keeping them for your zimmer Andy?
#10 Post by D-Rider » Wed May 18, 2011 9:22 pm
Aladinsaneuk wrote:You keeping them for your zimmer Andy?
I don't have many German rooms to which you can attach a set of TBs
#11 Post by Aladinsaneuk » Wed May 18, 2011 9:24 pm
Tch - that dementia is a bugger.... Poor lamb
#12 Post by Nooj » Wed May 18, 2011 9:53 pm
MartDude wrote:Not Capos or Futuras
Are they different, or just smaller bore?
#13 Post by MartDude » Wed May 18, 2011 10:02 pm
Both, I think. When I was discussing the possibility of fitting a Hooked airbox mod with Griff, he said he wasn't sure whether an off-the-shelf one fit as is, as the Fut TB's are different to the Mille/Falco ones; I'm sure he said they are smaller, & located slightly differently (but that was a year ago)
#14 Post by Nooj » Wed May 18, 2011 10:14 pm
Had a look on Ultimate Parts, they look different, similar in places, but definitely not the same thing as Falco/RSV ones.
banjaxxed1
#15 Post by banjaxxed1 » Sun May 22, 2011 8:48 pm
1 set left, any takers?
