Suspension linkage
paganman
Suspension linkage
#1 Post by paganman » Tue May 10, 2011 10:11 pm
Refitting my Ohlin's after a bit of tinkering, and I thought I'd slap some grease on the linkage bearings. Wish I hadn't bothered now as attached to my greasey finger were 3 roller bearings!
Looks like one of the bearing cages has started to disintegrate, and the others look a bit 2nd hand too. Just checked on line and it appears to cost around £110 for the 6 bearings, seals and sleeves. Does anyone know the bearing code for these, so I can remove some of the financial sting?
Thanks in advance
1st Italian bike. 1st V-twin, loving it!
#2 Post by D-Rider » Tue May 10, 2011 10:19 pm
The linkage bearings are UNCAGED full compliment bearings. They are not as easy to source as the caged variety but are better for low-speed, high-load applications such as in these linkages.
..... and, of course, all those bearing codes are in the Forum's Aprilia Technical section ......
https://www.ridersite.com/viewtopic.php?t=5295
anzacinexile
#3 Post by anzacinexile » Wed May 11, 2011 7:36 am
Got mine by removing the bearings and slapping them on the counter of my local bearing shop. 5 minutes later., nice new bearings and seals at a fraction of the Aprilia prices.
BTY, the needles are meant to come out, nothing holding them in once the shaft is out
paganman
#4 Post by paganman » Wed May 11, 2011 7:45 am
anzacinexile wrote:Got mine by removing the bearings and slapping them on the counter of my local bearing shop. 5 minutes later., nice new bearings and seals at a fraction of the Aprilia prices.
Looks like plonker of the day award goes to..................ME.
I'll check my manual next time before fearing the worst.
Many thanks for your help.
