spring work done
davebms
spring work done
#1 Post by davebms » Wed May 04, 2011 8:37 pm
hello all , i have fitted oberon reservoir caps +clutch slave cyl hell lines
striped cleaned all brakes ebc hh pads had mid panels and belly pan sprayed . and a sprinkle of s/s pro bolts (via noog) the bolts have realy made the bike look very tidy ! i am saving up for some more
the rear disc holding bolts are tatty ,BUT will stainless steel bolts stop the speedo working :smt017
dave
red and black v twin
#2 Post by Aladinsaneuk » Wed May 04, 2011 8:49 pm
leave them well alone if you want the speedo to carry on working.....
#3 Post by Nooj » Wed May 04, 2011 8:53 pm
As much as I'd like to sell you some, they will indeed stop the speedo working :smt012
davebms
spring work done
#4 Post by davebms » Wed May 04, 2011 9:46 pm
:smt013 OK the wise men have spoken , will have to settle for cleaning em up... bikes going very well at the moment , will bed the new front pads in more but the front does not feel as good as the pink 3 cyl bike i just sold ?
dave
#5 Post by Aladinsaneuk » Thu May 05, 2011 4:59 am
https://www.ridersite.com/viewtopic.php?t=3763
may I suggest that you start with that guide - and bleed them
the falco standard brakes are good imho - so good i have not switched to the upgraded ones....
(And i could have done a few weeks ago but could not justify it....)
#6 Post by Nooj » Thu May 05, 2011 10:16 am
I disagree, in the grand scheme of braking these days the OE Falco brakes are heading down towards average-to-good performance, so the brake upgrade is worth doing IMO, but... to make a REAL difference you'll need 4-pad calipers, braided lines and billet levers, you'll then have about 95% of the performance of the radial caliper set up on new Aprilias. As it is the OE set up (especially on older bikes) has I'd say about 75% of the radial's performance.
GregD-UK
Brakes...
#7 Post by GregD-UK » Thu May 05, 2011 3:52 pm
I concur with nooj, got four pad calipers and new hel lines with 5.0 oil in and some shorty levers... What a difference :smt002 if you can, you should upgrade :smt001
Falco9
Re: spring work done
#8 Post by Falco9 » Thu May 05, 2011 6:52 pm
davebms wrote: the rear disc holding bolts are tatty ,BUT will stainless steel bolts stop the speedo working :smt017 dave
I bought genuine Aprilia new one from here and at just 49p each is it worth refurbishing the old ones??
http://www.motosportaprilia.com/Parts.a ... 4&tblname= 44 Rear brake caliper
F9 :smt006
#9 Post by DavShill » Thu May 05, 2011 7:06 pm
Great shout Rich thankyou. I fitted my OZ wheels last week and damaged one of the disc nuts. Eventually got it removed and replaced it with a SS bolt. Was careful to make sure I used a washer to get the correct free space between bolt and speedo sensor. Took it for a ride and the speedo had a thrombie! very erratic and got worse the faster I went. Realised it could only be my botch so managed to rescue the old nut and all is well. Think I will replace them now using your link. :smt001
davebms
#10 Post by davebms » Thu May 05, 2011 8:35 pm
F9 :smt006
good call will get em new
re brakes . have just fitted HELL lines stripped and cleaned calipers new EBC HH pads and new leavers (long) as Aladinsaneuk suggests i will re bleed . i don't think i can upgrade at the moment murfys law will probably get me and new lines will be req :smt017
if i look on ebay, what bike do four pad calipers come from ?
dave
#11 Post by Aladinsaneuk » Thu May 05, 2011 9:27 pm
thats a secret till I get mine...
joke
think they are off the later factory mille's - d-rider is more familiar than i am on them - i expect he will be along soon
(I know he is away atm so I will try to ferret through some posts and see what I can find)
#12 Post by Aladinsaneuk » Thu May 05, 2011 9:51 pm
2002 milles and later
#13 Post by D-Rider » Thu May 05, 2011 11:02 pm
Nooj wrote:I disagree, in the grand scheme of braking these days the OE Falco brakes are heading down towards average-to-good performance, so the brake upgrade is worth doing IMO, but... to make a REAL difference you'll need 4-pad calipers, braided lines and billet levers, you'll then have about 95% of the performance of the radial caliper set up on new Aprilias. As it is the OE set up (especially on older bikes) has I'd say about 75% of the radial's performance.
GregD-UK wrote:Hi all,
Sorry you guys but I've got to disagree.
As I posted a couple of weeks ago
D-Rider on 26th April wrote:OK ..... delay over .....
Have now fitted:
Front Brakes:
  • 4-pad callipers - serviced before being fitted
    New Sunstar Discs
    Hel braided hoses (70degree banjos at master cylinder, straight banjos at callipers, Right hose: 62cm, Left hose: 67cm)
    Brembo racing radial master cylinder (not the normal RSVR radial master)
    Renewed brake fluid
Verdict:
Front Brakes:
  • Hoses fit but would have been more comfortable if a little longer - right side OK but an extra 1cm would do no harm, left side would be more comfortable 2cm longer. That said they are not tight.
    Angle of brake lever is more horizontal than I would like but there is no choice due to the lever/span adjuster contacting the front fairing sub-frame at full lock if tilted further.
    Had them on a few days now
    Compared to previous standard setup (Brembo 2-pad callipers, freudenberg hoses and standard master cylinder), there might be a small improvement - need more time to assess but it's certainly not a "night and day" difference.
    I did note recently when I cleaned up the "buttons" on my discs and cleaned the pistons on the standard callipers etc that I found it hard to see there was much room for further improvement ..... guess I was right.
    D-Rider on 6th April wrote: BTW last weekend I cleaned up my rotor buttons and the callipers and pistons on my standard Falco brakes. That has firmed them up hugely .... didn't even change the brake fluid or bleed them.
    I'm even wondering how the 4-pad callipers / radial master cylinder and braided lines is going to improve on that!
I am sure that had I not serviced the standard setup only a couple of weeks before "upgrading" I'd have been bowled-over by the improvement but having the "luxury" to compare with a freshly serviced standard setup, I don't think there is that much of a gap between them.
