Radiator fans
- Falconihlist
Radiator fans
Just a quick request to confirm operation of the radiator fans. As the weather has been of a nicer state recently, the bikes running temperature has obviously increased a bit quicker in town. Am I correct in thinking that it is normal for only one fan to kick in as the temp increases into the mid 90's and as it gets to the upper 90's then the second fan will kick in?
If this is the case then all's good, if not, then where should I start looking.
Black is fastest!
- anzacinexile
- Falconihlist
Both fans definitely work, I saw both running at the same time above 96 degrees, I was just curious though, as when it is between 92 - 95 only the right side spins up, and as it increases then the left side also kicks in.
I wasn't sure initially, mainly due to the fact I have the R&G crash bungs fitted, and the left side one squashes the fan motor into the back of the rad if you don't trim it down.
Black is fastest!
- anzacinexile
- Falconihlist
Righto, a bit of further imagineering is required then.
Just run the bike up to operating temp and noticed the following:
94 degrees right hand fan kicks in, no voltage at left fan
97 degrees left hand fan also kicks in, both fans running
as temp drops again below 97 degrees, left fan shuts down
as temp drops further below 94 degrees, right fan shuts down.
I tried this with the crash bung fitted and removed, no clearance issues there. Both fans spin up freely with no excess freeplay or resistance. Both fans recording same resistance through them.
Output at relay is fine, and from what I can gather the voltage and resistance through the wires connecting the relay to the fans is fine.
I really don't want to be stripping down the harness and rebuilding it.
Black is fastest!
- Falconihlist
This makes no sense whatsoever. If you look at the circuit diagram that are wired in parallel with each other - powered from the same relay. They MUST work together (unless someone has done something very odd with the wiring)
- Falconihlist
I have to agree with you, if it was in series, or it had a dual stage temp sender, then I would be happy to leave it at that, but after checking everything, I just can't fathom it out.D-Rider wrote:This makes no sense whatsoever. If you look at the circuit diagram that are wired in parallel with each other - powered from the same relay. They MUST work together (unless someone has done something very odd with the wiring)
At some stage all the electrics will propably need removing due to the bodge job of the previous owners Hawk alarm, which I am still trying to remove. There's wires all over the place, and they have just been spliced and wrapped in electrical tape. NOT a professional job at all.
At the end of the day though, if the fans do their job, then it should be alright to crack on. I'll just bear it in mind should the temp start to get excessive.
Black is fastest!
- Falconihlist
Righto, went out and stripped all the connectors all the way through the bike, and got the bike out for a good run. BOTH fans are now kicking in at 96 degrees at the same time, switching off together and operating in parallel
I haven't got a clue what caused the series running, am happy now that it works as it should
Black is fastest!
