Had a little spill outside my house, brand new tyre on, rode to junction 40m from my garage, looked up the road as usual, then pulled away slowly. As I did this, didn't see the huge deisel spill, back low, then high sided me at 10mph
New levers, new crash bungs and some damage to brake pedal. While lying down with the bike, it didn't kill the engine (defective tilt switch maybe!) Leaned over and killed the engine. An passer-by helped me up the bike.
I brought her homeand serveyed the damage. And later I felt abit achy, my dainese swag saved my shoulder and back and boots helped as well.
Anywho, I duly checked the bike was ok and on start afterwards it kinda
Called out recovery off my bank account, the guy put a booster on the battery and she fired up straight away. Soon as he took the booster off, it just died
The dash looks quite weak, and it went to reset, when I tried again the starter relay was clicking like mad. Jumped into car, went to newcastle aprilia dealer, had a starter relay for a honda same numbers on the side. This was last night. I went home and got my optimate and took battery out and charged it in her house. This morning got 13.65 on the battery.
Put it back in, got 12.68 on static no draw. Turned ignition on, 9.84 and very faint on the dash, and again, the rear starter relay clicking, the new one! I am stuck in northumberland and scratching my head. Woops, forgot I replaced my tilt swtich as well. How do you check for drain on loom or frame?
Cheers for any help, by the way it is cracking the friggin pavements here. And all I can here is bikes giving the beans in the distance
Cheers, in advance...
