I then had a good ride out to bed the bike in and do all those little checks etc..that are needed after a big rebuild
Plus points. She pulls like a train, runs super smooth, all the gears, clutch, brakes etc.. were super. She wheelies everywhere and I had a grin on my face like a large smug cheshire cat
Bad points ........ Speedo failed after just 5 miles (probably the sender unit) and I hit a bump with surprsing consequences. The bike cut out a couple of times very quickly and then immediately recovered but the right hand part of the dash stopped working with just "DIAG" lit. The rev counter was fine as were all the other electrics
The bike continued to run perfectly all the way home and after turing the ignition off & on again the dash now appears to be fine with all the info working
The Hook airkit sounds fantastic as do the Carbon Cans, and I am a very happy camper at the moment
So does anyone have a spare speedo sender unit?? I think they'll be a few on Fleabay I'm sure
Any ideas on the engine cut out would be good to hear. I have checked all the connectors I can get to since being home, and I've found nothing amiss so far
F9
