Indicators
Indicators
Hey Guys,
Been messing with the falco, doing a few, standard mods. One of them is a new set of indicators to replace the mahusuve originals.
I havnt gone for anything flash because of my budget, but i bought a set of 4 indicators, just normal bulbs.
Fitted them to the bike tonight, but when each half of the indicator circuit is complete, neither indicator works. Romove either the front or rear and the other indicator will flash like normal. Im guessing the indicator relay isnt powerful enough to supply buth indicators with enough power. Does that sound about right? if so, where would i find a more powerful relay?
Thanks,
Dale
Thanks,
Dale
- Tweaker
- Main bike: BMW R1250RS
The standard Falco bulbs are 10w and most replacement ones are 21W. You can replace the flasher unit with one from Halfords for around£6-7, You need the rectangular one rated at 2 x 21W with 2 pins on it. It''s a direct replacement for the originals.
The LeD ones might give you even more grief as they tale very little current and not usually enough to get the relay working. I believe some have built in balast resistors but, if not, you'll have to wire some in parallel with each side. There's a few threads on here about it somewhere.
- HowardQ
Dave beat me to it, exactly as he says, the problem will probably be down to 21w bulbs rather than 10w.Tweaker wrote:The standard Falco bulbs are 10w and most replacement ones are 21W. You can replace the flasher unit with one from Halfords for around£6-7, You need the rectangular one rated at 2 x 21W with 2 pins on it. It''s a direct replacement for the originals.
Check that first, Ditto also for LEDs.
Take a ride on the Dark Side
thanks for the info, i thought it would be the relay at fault.Tweaker wrote:The standard Falco bulbs are 10w and most replacement ones are 21W. You can replace the flasher unit with one from Halfords for around£6-7, You need the rectangular one rated at 2 x 21W with 2 pins on it. It''s a direct replacement for the originals.
When i ordered the led indicators i also bought the reccomended 2 pin led relay, so hopefully these together will work!
Thanks for the input as usual,
Dale
Ok, falcopops, you are right, i need to do the dash mod. i fould the article on af1 here.
Only problem is im not sure which diodes i need. Can anyone point me in the right direction? gonna go to maplins as soon as possible -0 i want to get this finished today!
found them - off to maplins...
Dale
Dale
