throttle body balancing
Hey guys,
i bought a carbtune pro(4 cylinder jobby) ages ago, but never got round to balancing the throttle bodies. I have done the carbs on the gpz a hundred times before, but dont have a clue how to do throttle bodies. Can anyone write up a short guide on what to do/how for me please?
Thanks,
Dale
Thanks,
Dale
Kool. I will print off the guide at http://home.comcast.net/~sl_mille/synch.html and follow those instructions.
Dale
Dale
Yeah - Ken's site has some useful stuffDalemac wrote:Kool. I will print off the guide at http://home.comcast.net/~sl_mille/synch.html and follow those instructions.
Dale
Check the condition of the plugs on the front and rear, see if theyre excessively different?
Remove one plug lead from the front and see if it changes the running, then do the same for the rear, so in the end youve done it with all plug leads? Should show whether one of them is dodgy or not. Obviously one plug lead at a time... not all in the same go..
Just dont shock yourself in the process..
Thanks for the suggestion. Just got back from halfords - cant deal with those stupid latching clips. (whatever they are called).Kwackerz wrote:Check the condition of the plugs on the front and rear, see if theyre excessively different?
Will go back down and check everything it right.
Thanks,
Dale
yep, its perfectly in the way which is why i unplugged it!Falcopops wrote:![]()
Beat me to it. When I did mine I unplugged the injector connection ao I wouldn't bugger it up getting the slipper clutch tube off and forgot to reconnect.
Sorry, I should have warned you, but I thought only I could be that stupid.
I took quite a while to balance them. The best setup i could find was front 2.25 turns out and the rear 1.75 turns out. It now rides much smoother, and is a bit nicer on the power. have lost some of the engine braking effect though :(
- Falcopops
Did you bugger about with the trimpots on the ECU?
Mine made sod all difference, so they aren't activated with my chip, roll on payday so I can get Gabro one.
Just had a look at my post and I had 1.75 front and 2.25 back, although that was from memory and I am very stupid.
Nope, didnt touch the ecu, just the throttle bodies.Falcopops wrote:Did you bugger about with the trimpots on the ECU?
Why?
Dale
