Clutch packs
Falconihlist
Clutch packs
#1 Post by Falconihlist » Wed Mar 02, 2011 2:32 pm
Are the RSV clutch plates different to ours? I know they use different part numbers but has anyone used them on a Falco?
Black is fastest!
GregD-UK
Engine...
#2 Post by GregD-UK » Thu Mar 03, 2011 8:35 pm
Thought the engine was the same :smt017 Just ECU, electrics, frame, suspension etc different :smt002
Wait till the old gits come on and give their 2p worth :smt003
#3 Post by Aladinsaneuk » Thu Mar 03, 2011 8:52 pm
while waiting for andy et al, am pretty sure they are interchangeable......
Falconihlist
#4 Post by Falconihlist » Thu Mar 03, 2011 9:20 pm
seems bizarre that the friction plates are a different number on the falco and RSV, but the steels are the same.
Black is fastest!
#5 Post by D-Rider » Thu Mar 03, 2011 9:35 pm
Falco and early Mille all use the same friction plates - compare part numbers on Ultimate parts website:
BTW engines are basically the same but gearbox is different hence the different gear change mechanism / the easy change to a racing shift pattern
