heated grips?
- furygan man
heated grips?
Me's thinking of getting some heated grips, have done a couple of searches but most are old threads. Any recomendations? Oxford seem the most popular, they have an original and a sport version, i picked up on the positioning of the controller might need some assistance in the wiring to relay etc
Are they slightly thicker than Falco ones as this would be an advantage?
I've got oxford ones, they are slightly thicker than the standard ones. I preffer it this way - got small hands :/
They're power from the battery through a relay hidden under the black screen plastic thingy. The relay switch is powered from one of the fuses on the RHS so it switches off once you turn the ignition off.
The LHS relay box bolt is good for placing the controller bracket (LHS of your clocks).
HTH.
HTH.
- furygan man
Thanks Dyzio, i read your post from 'the past'dyzio wrote:I've got oxford ones, they are slightly thicker than the standard ones. I preffer it this way - got small hands :/
HTH.
I have oxford - they do need to be trimmed to fit on the falco bars
hanna has R&G - these are thinner than the oxford ones and cheaper - we paid 25 quid for hers
If I was to redo mine I would go for R&G
- furygan man
the oxfords are a little bulkier - and i have small hands :)
i also prefer the controls - the oxford ones i have have a rotary control, the R&G one is a smaller panel
the R&G ones feel better quality
- furygan man
Doesn't the forum's Arthur Daley hold an R&G franchise?
I wonder what he could do them for?
Calling Nooj ...... Calling Nooj ......
(might even be tempted to replace my Saito heated grips - They do the job OK but the switch has never been easy to mount)
If you want to go for the R&G ones I can get them. Will knock 5% off for forum bods.
