TB balancing
TB balancing
#1 Post by Nooj » Fri Jan 14, 2011 12:44 am
Morgan Carbtunes OK to do this with on the Aprilias? Will be using them on Debz' FZ6 as well.
#2 Post by Falcopops » Fri Jan 14, 2011 1:35 am
Should be fine, if a mate of mine hadn't lost the ones I lent him I would have used them without question.
Nice quality piece of kit. Make sure you read the instructions 1st, I didn't and just connected them to my old Suzuki without making up throats and they were all over the place. Once done properly they were so easy to use!
When I've got the cash spare I'll get a new set.
back_marker
#3 Post by back_marker » Fri Jan 14, 2011 7:38 am
Yep, no problem.
Are you thinking of buying or do you already have them? I invested in a set and I am only down the road in Reading if you want to save yourself the expense.
- Steve McQueen
#4 Post by D-Rider » Fri Jan 14, 2011 9:37 am
As others have said, it's fine - it's what I use. :smt023
#5 Post by Nooj » Fri Jan 14, 2011 4:29 pm
Back Marker! Yes please!! Won't need them for a few of weeks yet, waiting on some parts before I recombobulate the bike and get it running again, mid Feb I expect.
Throats??? Care to elaborate?
back_marker
#6 Post by back_marker » Fri Jan 14, 2011 4:58 pm
You have to insert a smaller piece of tube within each of the pipes to dampen the pulse from the engine and give a steady reading. Not easy to explain but all of the bits come as part of the kit, you just have to put it together.
- Steve McQueen
#7 Post by Nooj » Fri Jan 14, 2011 5:23 pm
Sort of makes sense. I've used them once before, but that was a few years ago.
