Question for heating engineers/plumbers
I'd be grateful for recommendations for TRVs (15 mm), please. Ideally ones that are likely to be available from Plumb Centre, Screwfix etc - or mail order, if you could also recommend good sites.
Having just had new, draught-free windows fitted, and the multi-fuel stove's (does the central heating) flue replaced, we're finding it almost too warm, especially in the bedrooms. That's the downside of solid fuel - difficult to regulate quickly.
- Willopotomas
- Willopotomas
AFAIK, parallel. At least, I can isolate one rad without the others being affected.Willopotomas wrote:are the rads plumbed in parallel or in series?
However, I've just discovered another, more serious issue. There appears to be a pinhole leak in the back boiler, into the firebox. Very small, but noticeable. A friend with the identical stove had the same problem recently, & was able to have it repaired, so I'm hoping ours is repairable. However, as ours is, as it were, built in, it will be a major hassle to remove it for repair - it's plaster-boarded & plastered right up to it, and the new flue liner's been cemented to the stove's flue connector. We could really do without the disruption, not to mention the lack of heating, and the expense. Is there anything on the lines of Radweld that might effect a temporary repair, without harming the rest of the system?
- GregD-UK
Fault + TRV'S...
Most trv's do the job, pegler are a good make, your bedroom's should be 10 degrees cooler than your living spaces. As for the pin-hole in the HEX, that is known as an AR (At Risk) situation. The pin-hole can obviously cause a crack as the metal will expand and the hot water can empty out of it and be a very bad scenario to deal with. Most HEX's can have a small weld put in, but, long-term, new HEX required
A good GasSafe Engineer could sort it out for you... Cost is dependable on how well you know him...
- GregD-UK
Dual Fuel...
Yes, a small pot in the back (HEX) as we call them in the trade
You could put in 2litres of rad weld. I (Gas Engineer) would always recommend to take out and repair properly or replace. As I said before, the classification of AR (At risk) for this particular fault. I can understand you reluctance to mess since you have had some remedial work done recently. You have to weight up the expense and inconvenience OR no heating and hot water my friend..... As always, a competent local engineer will give you options. Radweld will be a tempoary fix, as that is all radweld is
Greg - my apologies if I seemed to appear disparaging of your expertise - was just hoping to stave off the inevitable until the end of winter. We were planning on replacing our central heating system with an oil-fired one later this year (no mains gas here) - but we'd rather not do it right now
- GregD-UK
Oil or LPG...
Well, as I said, just chuck some radweld in and hope it lasts till after this lovely winter
I would suggest you look at an LPG boiler. Oil is dirty and almost as expensive as LPG! Much cleaner to work on LPG
Depending on how far out you are from civilization that is.
Re: Oil or LPG...
Unfortunately, we're miles from a mains gas supply, so it'll have to be oil, or LPG tank. LPG would be convenient, as we have an LPG hob. We've got a local heating engineer, recommended by a friend in the heating equipment trade, coming to do a survey and give recommendations.GregD-UK wrote:Hi all,
Well, as I said, just chuck some radweld in and hope it lasts till after this lovely winterI would suggest you look at an LPG boiler. Oil is dirty and almost as expensive as LPG! Much cleaner to work on LPG
BTW, is this stuff likely to be any good for a temporary fix for our problem?
http://www.google.co.uk/products/catalo ... CB8Q8wIwAA#
http://www.plumbnation.co.uk/site/ferno ... ak-sealer/
Many thanks, Greg. Shame you're not closer
Thanks Greg
2 litres of which one? This
http://www.plumbnation.co.uk/site/ferno ... r---500ml/
or this?
http://www.plumbnation.co.uk/site/ferno ... r---290ml/
If I use this
how do I apply it - into the header tank? The super-concentrate is applied via a radiator air-bleed thing - but I'm not sure if ours will screw right out.
Very grateful for your help on this, Greg - only ever done anything like this with cars.
or this?
If I use this
