Specific 'mods' advice
- furygan man
Okay a few 'Winter modding questions to be resolved, if anyone can help?
Bike is 01, 11k, original parts still fitted (relating to the info below)
RSV Swingarm (04>) (pre 04...sorry DR!)
Other than the swingarm itself, the hugger, the cable guide and the chain guide is there anything else i need to purchase or can the 'fitting' parts from the Falco carry over?
Forks (Showa)
Other than a basic service is it worth doing anything else whilst the forks are apart, i'm thinking valve/seals/springs etc...worth doing, would i notice a difference? (Getting the replacment yellow spring shock seviced as matter of course)
Chain/Sprockets
Thought whilst all the other work is gettig done i'd get these replaced too, some have gone down to 15 tooth front, have also read about keeping the 16 on the front and adding a couple on the rear as an alternative...thoughts?
Will get some/all of above done at same time together with suspension set up
HID bulb on order but that looks pretty straight forward thanks to DR's thread, the adjustable rearsets at Aprilia performance would be some nice bling but are very pricey!!
There's other stuff but this is the next step for me currently
Thanks as ever chaps!
Forks (Showa)
Chain/Sprockets
Re: Specific 'mods' advice
I don't believe that any of the Falco's plastic bits fit but picking them up from ebay is usually not too hard as Mille owners frequently upgrade to carbon items - all except the chain guide strip that protects the swinger from the chain of course.furygan man wrote:Okay a few 'Winter modding questions to be resolved, if anyone can help?
RSV Swingarm (>04)
The other parts are: Hugger, Chain Guard, Shark Fin
You may need a few tools - such as the shimano freewheel tool and I had to buy a socket in a size I didn't have - it's all detailed in the Technical section.
https://www.ridersite.com/viewtopic.php?t=5962
EDIT: Just noticed you are going for a post '04 swingarm - please ignore all the above - I was assuming the pre-'04 that most of us have gone for.
One of your bigger problems will be relocating the battery and removing the battery box as there is not enough clearance to the swinger.
There was also a batch of those swingarms that were recalled as they cracked - it was not uncommon for the dodgy ones to then appear on ebay - obviously avoid that batch.
I have no direct experience of the Showas (just the Marzocchis and Ohlins)furygan man wrote:
Forks (Showa)
I believe, like the Marzocchis, they are very good when serviced and set up right (though they are easier to change valving etc than the Marzocchis)
If you are stripping them, it's probably worth changing the seals.
Things you might consider:
Re-springing to suit your weight - assuming the standard springs are not a good match anyway - they may be
Re-valving to suit you
Also be aware that Ohlins do a cartridge kit for the Showas so you could upgrade to Ohlins internals.
Depends on how much you want to spend and how well they suit you now.
Certainly just a service, change of oil and setup can make a big improvement.
15/41 and 16/44 ratios are very similar indeed. When just changing the gearing, the cost effective solution is just to drop one tooth off the front.furygan man wrote: Chain/Sprockets
When changing the lot, it makes little difference as you will pay very little extra (if anything) for the slightly longer chain and larger sprockets.
There can be some fairly esoteric discussions about better wear rates and clearances from the larger sprockets but in reality they are insignificant.
I guess if changing the lot, go for 16/44 - it has no disadvantage over the 15/41 other that a tiny increase in unsprung weight and rotational mass.
Be aware that with the mille swingarm you will need to split and rivet the chain.
HID is not hard - though some parts can be a bit of a fiddle. I think the most difficult part for me was working out where to put the ballast.furygan man wrote:
- furygan man
Thanks DR, have no intension of doing the work, so no worries on the tools fitting etc they will be carried out by someone who knows what they are doing
When i was talking about the 'Falco' other bits i was refering to the bearings/nuts/bolts 'hardwear, thanks for the shark fin bit as i didn't realise that was seperate from the chain guard
the whole sprocket chain thing came up on AF1 and someone suggested the rear change to help with clearance from dropping the front one tooth...just one of the reasons i can remember the other reasons, but i know most on here have gone down to 15 front.
- furygan man
Some time ago I worked out the numbers for these ratios - probably worth posting them again:
The other thing that gets quoted is that the chain wear is much worse as the chain has to bend a lot more on the 15t sprocket ..... though as I worked out above, it's only an extra 1.5 degrees.
Far more significant is good chain maintenance ..... time for another plug for Scottoiler .....
From the above you will see the 15t brings the chain no more than 2.5mm closer to the swingarm - though I'm not 100% certain what the clearance is with the 16t sprocket.Falco Gearing – Comparison of 15/41 and 16/44 final ratios
Standard Gearing is 16/41
Max Chain Bend Radius and Angle Between Links
Standard 16t sprocket:15t sprocket:
- Bend radius (at chain pins) = 40.4mm
Angle between chain segments while on sprocket = 22.5 degreesComparison of Ratios:
- Bend radius (at chain pins) = 37.9mm
Angle between chain segments while on sprocket = 24 degreesCompared to standard gearing:
- 16/41 gearing = 0.3902 (standard)
16/44 gearing = 0.3636
15/41 gearing = 0.3658Relative difference in Reduced Gearing Options:
- 16/44 gearing is a reduction of 6.82%
15/41 gearing is a reduction of 6.25%
The relative difference between 16/44 and 15/41 ratios is only:.
- 1-(0.3636/0.3658) = 1- 0.9939 = 0.0060
or 0.6% different - so engine characteristics at any speed will essentially be identical
- furygan man
- furygan man
No more so than all the other stuff you're planning - probably less so.furygan man wrote:But isn't that more for people who ride regulary Pete, i'm lucky to get out every 3-4 weeks...and it's 'Inckley by the way!!
..... even for those from treacle-town
- furygan man
I'm going to go with 15/42 next time, up one on the rear.
- furygan man
Re Swingarm- have just checked and there's a top chain guard (long thin), a bottom one (triangle shape), then there's the one that sits/wraps around the front of the swingarm near the front sprocket...is that correct?
Anyone have an opinion on brake levers, mine are scratch and chewed, have seen the 'Ducati' ones on Ebay and also wondered about the Titax ones on there?
..."basically, fit a scottoiler while you are doing everything else"
...any particular one come recomended?
Yes, I think brake levers are a good thing - I always prefer to ride with themfurygan man wrote:
Have you tried gum instead? I believe Wrigleys is a reliable brandfurygan man wrote:..... mine are scratch and chewed,
I hear Scottoiler make a good one...."basically, fit a scottoiler while you are doing everything else"
